Help Identify These Bits and Pieces... Pics Included - BMW Forum - BimmerWerkz.com
Old 06-07-2009, 09:18 PM   #1 (permalink)
Serge88 is on a distinguished road
Exclamation Help Identify These Bits and Pieces... Pics Included
Greetings from down under, I recently purchased a 1993 318is and need a bit of a hand with identifying a few bits and pieces under the hood and in the cabin, the list is as follows.
1. Loose plug in engine bay, passenger side (RHD)
2. Loose connector with 2 points also passenger side only -
3. Loose connector with 3 points on both passenger and driver sides -
4. Loose wiring running from passenger side wiring loom and runs under the plastic radiator cover to driver side (brown/yellow) -
5. Now I am aware that possibly the 3 prong connectors may of been for the fog lights as they are not connected but the seem to have a different socket-
6. An educated guess tells me that these are the switches for the fog lights... but why are there 2 of them?
7. What is the function of the S.E.M switch next to the shifter?
Now the previous owner has installed a new front bar and angel eyes head lights which may have caused some of the wiring to not be completely utilised..
8. I also have an issue with the left front indicator not working, I have replaced the globe and tried to fit the indicator housing from the left to right and the housing/globe seem to be o.k therefore the problem lies within the wiring?
9. I also have an issue with the wipers working intermittently or on "High", could someone advise whether this is a relay issue or the motor itself?
Any suggestions/clarifications would be highly appreciated. thanks.
Serge.
Serge88 is offline   Reply With Quote
Old 06-07-2009, 09:34 PM   #2 (permalink)
There are two fog light switches, one for the front and the other for rear fog/rain light (like a bright running light for conditions in which the normal ones aren't bright enough). The switch by the shifter is likely to select transmission modes, like sport shift mode.
Refinishing my trim on the sixer Pics included AlpineSixAndSeven 1,6,7,8 - Series and Mini Cooper 0 01-10-2008 01:06 AM
Which One To Choose...pics To Links Included!! Qwietstorm 3-Series (E46, E90) 7 12-22-2004 11:36 AM
Need bits and pieces for my car crackerkorean 5-Series (E12,E28, E34, E39, E60) 6 07-27-2004 07:00 AM
I have questions... Help.. PICs included Braymond 3-Series (E46, E90) 8 03-04-2004 04:43 PM
Can you identify these BMW parts? *pics* WingsNThangs Bimmer Talk/Motorsports Talk 15 01-08-2004 01:50 AM
