HELP, e36 brake light curcuit fault code - BMW Forum - BimmerWerkz.com
Old 08-26-2004, 10:27 PM   #1 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
I bought a 98 328i about 2 weeks ago. I've been showing codes indicating that there is a problem in the brake light circuit. The brake lights work, but the lit dash light and obc statement "brake light curcuit fault" are annoying. I replaced the brake light socket pieces, but the code is still coming up. ALso, the car came with euro/clear lenses all around, and the codes were coming up. So after changing the socket pieces, the codes were still coming up, so I switched the lenses to the stock units (therefore also the curcuit boards, right?). Even with the stock units I'm getting the code faults on the OBC.
Any ideas on how to fix this?
Thanks,
Ted
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 08-26-2004, 10:32 PM   #2 (permalink)
Fadec40 is an unknown quantity at this point
How about the third brake light at the rear window?
Fadec40 is offline   Reply With Quote
Old 08-26-2004, 10:38 PM   #3 (permalink)
Reedalicious's Avatar
Reedalicious is an unknown quantity at this point
Send a message via MSN to Reedalicious
Do a search becuase atleast once a week a few people have this problem. You have to replace a swith inder the steering wheel.
Reedalicious is offline   Reply With Quote
Old 08-27-2004, 12:36 AM   #4 (permalink)
/Banned
okczy21 is an unknown quantity at this point
the brake light switch didnt work for me, i dont know what to do
okczy21 is offline   Reply With Quote
Old 08-27-2004, 07:48 AM   #5 (permalink)
Nunzio's Avatar
Nunzio is an unknown quantity at this point
Make sure that in the tail light socket where the holder plugs into the assemblies. If there is any corrossion on the contacts or the connection is not tight it will cause a higher than normal resistance in the circuit and cause a fault. It monitors that resistance and will trip the fault. Also use the bulbs (Euro) constructed with the silver material. The ones with brass tend to cause higher resistance. Good luck !
98 328is Sport Package M3-Spoiler and Front End,
Turner Motorsports 4 Wheel drilled Rotors.
Axxis Brake Pads, Teflon/Stainless Brake Hoses.
UUC Sachs Stage 4 Suspension.
Sway Bavarian Sway Bars.
H&H MotorSports Front and Rear Strut braces.
Conforti CAI and Shark Injector.
UUC System U DTM Exhaust
UUC Short shifter , Tranny Mounts and Clutch Stop.
F1Danza Lightweight Flywheel with M-3 Heavy duty clutch.
Factory BMW M3 Front Bumper with Splitter.
More to follow...MUCH MORE !
Nunzio is offline   Reply With Quote
Brake Light Curcuit Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 4 07-16-2005 12:13 PM
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
