Help Does A Blown Head Gasket/head Make Noise? - BMW Forum - BimmerWerkz.com
Old 03-15-2005, 08:00 PM   #1 (permalink)
E36k224 is an unknown quantity at this point
Im not familiar with engines
any help is great
does a blown headgasket or head make any type of noise?my car overheated
E36k224 is offline   Reply With Quote
Old 03-15-2005, 08:03 PM   #2 (permalink)
what noise do you hear?
i guess they could if it was really bad. but if it was bad enough to make noise i doubt that it would run very well.
Old 03-15-2005, 08:22 PM   #3 (permalink)
[snapback]312285[/snapback]
I ended up driving thecar home for a short period while the temp gauge was in the red
Noises came from the engine that sounded terrible like the pistons were overworking
The next morning i was curious to hear how the engine sounded and it sounded normal
but now I am concerned i did some damage to the engine even if it sounds fine.
I looked for oil in the coolant and there wasnt any, and the dip stick showed no whitish color
so I was just curious if you have a blown head or gasket, will it make noise if you rev the engine
Old 03-16-2005, 07:40 AM   #4 (permalink)
if the pistons sounded like they were overworking that would almost indicate no oil. was it like a knocking noise, a rubbing noise like metal on metal, a high pitched sqeek, or did it sound like air was being pushed out somewhere?
either way if it was making any sort of abnormal noise when the temp gauge was in the red something is probablly broken. when ever a BMW gets into the red it really mean pull over and shut it down. thats why they have a big red light that comes on when the needle gets over that far.
you could do a compression test to check for a bad head gasket, or you could take it to the dealer because it sounds like you'll need some work done anyway.
Old 03-16-2005, 10:39 AM   #5 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
i used to have a 1982 320i that had a radiator leak and i drove it once when it was in the red (to a friends to get soem water) and was ok afterwards, but i shutit off about 2-3 min after it entered the red zone, so not sure how yours is.
kyle_baker is offline   Reply With Quote
Old 03-16-2005, 09:54 PM   #6 (permalink)
capslinky is an unknown quantity at this point
there would be white smoke coming out exhaust if head gasket was blown.
capslinky is offline   Reply With Quote
Old 03-16-2005, 10:30 PM   #7 (permalink)
I think it's your water pump. I've heard blown water pumps make crazy noises after they went, and that would explain the overheating. How many miles on your pump now? I hopefully that's the problem, it should only be about $250 to have a shop replace for you.
Old 03-17-2005, 12:18 PM   #8 (permalink)
BMDub325is is an unknown quantity at this point
90% of the time if the head gasket is blown you will leak coolant, oil, and blow white smoke.
92' 626 ES
88' Mazda Truck
92' VW passaat (sold)
93' BMW 325is
86' BMW 318is
<img src='http://www.geocities.com/bmdub325is/images/current/signaturefinal2.JPG' border='0' alt='user posted image' />
<a href='http://www.geocities.com/bmdub325is' target='_blank'>***MY E36 BUILDUP PAGE***</a>
BMDub325is is offline   Reply With Quote
What the HELL is making this NOISE???? bimmer_boy 3-Series (E36) 28 01-18-2008 07:15 PM
Odd Noise? Won't turn over? kraze0g 3-Series (E36) 4 08-12-2004 12:47 PM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 02:25 PM
