HELP--A/C ISSUE - BMW Forum - BimmerWerkz.com
Old 04-11-2004, 03:16 PM   #1 (permalink)
slqgsxr is an unknown quantity at this point
Thumbs up
The mechanic called me today said he found a problem while changing the belts. On the A/C Compressor the clutch pulley was rubbing. He showed me that compressor main shaft was loose..(in would move back and forth) he said that was not normal..
I've never had any problems with the A/C..and it worked fine before. Well I had him put everything back together, but had him leave the A/C belt off for now.
Does this sound like a problem...The mechanic said if the compressor was to lock it could cause damage.
Any ideas? Does this sound like shit. ghead
slqgsxr is offline   Reply With Quote
Old 04-12-2004, 08:30 PM   #2 (permalink)
TECH's Avatar
The clutch will move in and out if you push and pull on it. If it moves up and down excessively, it is a problem. If it locks up, the belt would probably break, or it could kill the engine, or go up in smoke....
Old 04-13-2004, 01:54 AM   #3 (permalink)
roguesniper1's Avatar
Car: 97 528i and 94 325i
roguesniper1 is an unknown quantity at this point
Send a message via AIM to roguesniper1
REPLACE it at once. It is a known problem, not quite common though.
roguesniper1 is offline   Reply With Quote
Old 04-13-2004, 06:18 AM   #4 (permalink)
mmendell is an unknown quantity at this point
I'm in the process of a complete AC system replacement. The compressor went, and seems to have taken everything in the AC system with it. I've had the car for 3 months. Get it early.
1997 328I Sport Package
mmendell is offline   Reply With Quote
Old 04-13-2004, 12:29 PM   #5 (permalink)
Where is a good place to get the parts?
Clutch Issue? pamato 5-Series (E12,E28, E34, E39, E60) 9 10-27-2005 03:32 PM
Tiptronic issue - 325i 2003 freetodd24 3-Series (E46, E90) 1 10-14-2005 02:48 PM
Any Issue For Putting Obd I M3 Engine In 325i? r6bruin 3-Series (E36) 2 08-13-2005 07:12 AM
Bumper/bodywork/scratchpad Issue RokleM 3-Series (E46, E90) 4 08-04-2005 04:47 AM
01 330CI Turn Signal Issue qilfu 3-Series (E46, E90) 3 07-27-2004 11:11 AM
