help on brakes - BMW Forum - BimmerWerkz.com
Old 03-15-2009, 04:26 PM   #1 (permalink)
olynicole's Avatar
olynicole is on a distinguished road
help on brakes
hi ive got a 318i i want to put discs on the back. will the hubs off a 320 or something just bolt on or is it a big job. cheers
olynicole is offline   Reply With Quote
Old 03-16-2009, 10:55 AM   #2 (permalink)
basrite's Avatar
Car: 1995 BMW 320i, 17inch M3 mags
basrite is on a distinguished road
olynicole,
As long as it has the z-axle.. it should be pretty easy (please correct if i'm wrong).
The major aspects will involve the hub assemly, as well as the handbrake cables. You may need to replace the cables as the actuator in the hub is very different. Instead of acting on the existing brakes like a drum does, the discs are completely seperate from the handbrake assembly which are small drums inside the disc.
Most likely the whole upright assembly that contains the disc will need swapping over to be able to carry the caliper mounts etc.
If you can get hold of a full assembly from the 320 it shouldn't be too bad.. full days work.
J.
Yes... i'm a total car nut! Why else would I upgrade my mower to rev to twice its standard rpm!
basrite is offline   Reply With Quote
'06 M3 Brakes biz_banker M-Series (M1, M3, M5, M6) 4 01-14-2009 03:19 PM
Doing your Own brakes k2c69n 3-Series (E36) 16 03-27-2006 03:29 PM
Brakes Montizzle 3-Series (E36) 10 01-20-2006 02:27 PM
brakes socalguy 3-Series (E36) 8 04-16-2004 01:48 AM
The brakes have been done! nosuchsol Bimmer Talk/Motorsports Talk 5 04-08-2003 08:47 PM
