help !! brake problem - BMW Forum - BimmerWerkz.com
Old 03-03-2006, 05:33 PM   #1 (permalink)
walshja is an unknown quantity at this point
ok, last night I changed my rear brake pads, rotors, and installed a new brake pad wear sensor.
took the car out today, and everything was fine.
all of a sudden on the way home, I heard a HUGE bam !!
the rear passenger brake was clamping closed then releasing whenever I would touch the brake pedal.
thought I could make it home not using the brakes when it started ceasing randomly
had to pull over and leave the car in a gas station.
what could be wrong?
HELP
1994 325iC, 130k miles
walshja is offline   Reply With Quote
Old 03-03-2006, 11:33 PM   #2 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
wo that sounds pretty bad, I had a similar problem with my truck, but it was the handbrake cable, that had not been adjusted..
Old 03-05-2006, 12:50 PM   #3 (permalink)
BMW Kraft's Avatar
BMW Kraft is on a distinguished road
that's why i'm still hesistant to change my own rotors and pads
'92 318i - Bilstein Sport Tuned Suspension, Performance Tuned Chip
///BMW=-
BMW Kraft is offline   Reply With Quote
Old 03-05-2006, 12:57 PM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
did u blead the brakes??? did u refill on brake fluid?
-SOLD..
R.I.P Fast 6
Old 03-05-2006, 01:20 PM   #5 (permalink)
well, what happened was the brake pad carrier mounting bolt came off when I was driving !!
i didn't have a torque wrench, so apparantly it just came lose and fell off because it was not tightened properly - lesson learned: GET A TORQUE WRENCH !!!
so the caliper was swinging out and grabbing the wheel, causing it to lock up.
so I took the other brake pad carrier mounting bolt off, went to home depot and purchased a new bolt for .75 cents (BMW doesn't carry that bolt in stock)
this was a stupid error on my part and this should not deter anyone from changing your own brakes.
this is one of the easiest jobs you can do, that will save you huge amounts of money.
i didn't need to bleed the brakes or refill any fluid. and actually, if anything, I possibly would have had to remove some brake fluid during the job. when you change your brakes you have to compress the piston into your brake caliper, which causes the fluid in your resevoir to rise. and since changing your pads and rotors does not involve opening up your brake hydraulic system, there is no need to bleed the system.
seriously, you only need a 7mm & 8mm hex wrench and a 14mm wrench( I think ) to do the entire job. This is the first brake job I have done in over 20 years, and it only took me maybe 3 hours. If I was to do this again I bet I can get it done in 1.5 hours.
In fact, my wifes 528iT needs both front and back brakes, and my mechanic gave us a quote of $475. I just purchased all the parts I need off ebay to do the entire job for $255.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8043685899
so give it a shot, and if you have problems simply post the problem here and someone will help you through the process !!
Brake Problem on my 528i jeppcharts 5-Series (E12,E28, E34, E39, E60) 4 02-14-2006 05:49 PM
Brake Problem e30bmwes 3-Series (E21, E30) 5 02-20-2005 03:07 PM
Weird Brake Problem '94 318is ultraviolet353 3-Series (E36) 5 10-19-2004 06:52 PM
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
