HELP BMW WONT START 318is Coupe UK spec - BMW Forum - BimmerWerkz.com
Old 01-07-2009, 09:33 AM   #1 (permalink)
Camaroyal's Avatar
Car: 93' BMW 318is coupe+Prelude+Civic
Camaroyal is on a distinguished road
Unhappy HELP BMW WONT START 318is Coupe UK spec
Hi, I recently (Saturday) bought a 1993 BMW 318is coupe. Drove it Sunday and Monday and on Tuesday got in it and it wouldn't start. Got someone to jumpstart it but it still wouldn't go. It turns over fine but still doesn't start. Had it jumped using a booster pack, still nothing. The guy that came out thought it might be the fuel pump? Tried to find the fuse but couldn't figure out exactly which one it was. Any ideas? Your help would be greatly appreciated. Thanks.
Camaroyal is offline   Reply With Quote
Old 01-07-2009, 10:43 AM   #2 (permalink)
The fuel pump is a good start; it might be the pump itself if the fuse is good. That was the issue on my E30.
Old 01-07-2009, 11:26 AM   #3 (permalink)
Camaroyal's Avatar
Hi, Thank you for your suggestion. If it does turn out to be the fuel pump (saying I can get someone else to look at it, who's not busy :/) is this something that is hard to do/ are the parts hard to get and will it take a long time for a mechanic to do it? I'm so stuck without a car
Old 01-07-2009, 11:42 AM   #4 (permalink)
You may be able to locate the pump in diagrams from realoem.com
Old 01-09-2009, 10:36 AM   #5 (permalink)
Camaroyal's Avatar
Hi, Thanks for your input. Still haven't been able to get the car fixed. Did try to look up the part on the site you mentioned but didn't have much luck, although I have now been able to source the part. It's just a case of getting someone to figure out exactly what's wrong with car and then getting them to do it. If anyone else has any other ideas on why it won't start then please put them here. Could it be that the fuel lines are clogged up somehow and if so would the whole fuel pump have to be replaced or can the lines just be unclogged?
Old 01-09-2009, 10:47 AM   #6 (permalink)
If the lines are clogged and the pump works, replacing or cleaning them should help along with a new filter.
Old 01-09-2009, 11:22 AM   #7 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Here you go:
RealOEM.COM * Part Category Selection
All you have to do is use the pull bar and click on what you want to see, then click on the diagram you want and it will enlarge and show all the part numbers.
Old 01-09-2009, 11:24 AM   #8 (permalink)
marti5's Avatar
Do you have a spark at the plugs???
Old 01-09-2009, 12:51 PM   #9 (permalink)
Camaroyal's Avatar
Hi, wrote a better reply then it wouldn't go so I've now had to write it all again anyway here it is: Finally got a garge to come and get it but being so special my car didn't have the tow place on it! They are going to have to come 2moro with a recovery truck. More time wasted! Hopefully it will be just the fuel lines or something simple and quick. As for spark, I'm actually not sure if it's getting spark or not. I know it's got to have spark to run. I can't remember if the first guy that looked at it said it did or not. I assume for him to have moved onto thinking it was the fuel pump that it must have had spark.
318is wont start please help mitch_ells 3-Series (E36) 3 05-25-2008 12:18 PM
95 318ic wont start, egine wont turn over. (couple cold days) vic318ic 3-Series (E36) 2 02-05-2007 10:00 AM
00 M5 wont start JACK BAUER M-Series (M1, M3, M5, M6) 11 08-12-2004 06:09 PM
Wont start linx76 5-Series (E12,E28, E34, E39, E60) 4 01-27-2004 03:03 PM
