Originally Posted by 97blkonblk what do you think about getting fog lights off of ebay? do you think they will be good....or should I look somewhwere else? |
Hmm. Not really sure. If you go the ebay route, make sure they are OEM replacement. I had to replace one of mine because the lens was cracked and I was luck to find a used original from Ebay. If you see a set you like, dont be afraid to ask the seller questions. Make sure it has the stock mounting locations. I was looking at a set on there (ebay) and looking at the picture, the mounting didnt look anything like mine. If you buy some and dont like them, you can always turn around a resell them on Ebay as well. Or just keep a watch out for some used ones like I did. Good luck and let us know how you make out.
