Help!!!!!!!!!!! - BMW Forum - BimmerWerkz.com
Old 03-15-2005, 08:18 PM   #1 (permalink)
Steinkek is an unknown quantity at this point
Ok i replaced my spark plugs today. It definitly needed to be done because the plugs we pulled out were toast. We thought everything was going great. It started up great after i put every thing back together. So of course i took it out to drive and something started to go wrong. About 2-3 miles down the road it started to kind of stutter when i pushed on the gas. So when i got to the stop light it went to idle and idled really low (almost died) so i gave it some gas and that killed it. 4 or 5 tries later it started and gave me little to no power till i got it above 3 rpms. Luckly i was able to get it home, keeping it above 3 rmps just to keep it alive. I got home and re-read the pelican parts page on how to replace my plugs and it said that you should not use the anti-seize gell which of course the guy at the autozone told me to use along with another gel for the top of the plug that helps keep out water and stops corrosion. We then went back and wiped the stuff off the plugs and it still didnt really want to run. What do i do? Has anyone changed their spark plugs before?
Sorry about the length, Kris
Steinkek is offline   Reply With Quote
Old 03-15-2005, 08:22 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
are u sure they are in all the way...???
-SOLD..
R.I.P Fast 6
Old 03-15-2005, 08:27 PM   #3 (permalink)
we set the torque rench to 18.4 like it said to do on the pelican part web page. When we removed them they were extreemly tight, and these didnt seem to go in as tight. So do you suggest making it tighter? Could making them tighter than 18.4 cause any problems?
Old 03-15-2005, 08:57 PM   #4 (permalink)
njtech is an unknown quantity at this point
are you sure the coil connecters are secure? Grounds tight? Make sure that when you put the oil cap back it is seated completly. HTH
Steve
njtech is offline   Reply With Quote
Old 03-15-2005, 09:04 PM   #5 (permalink)
Another thing is that it had bosch plugs in there and i replaced them with the NGK plugs which is also an option in the owners mannuel.
Old 03-16-2005, 12:05 PM   #6 (permalink)
RIBEMR26's Avatar
....I would return them to the zone and see if they will replace them since they gave you bad info...btw...never rely on those guys for bimmer advice...most of them know nothing about our cars...
if they wont replace them, buy new ones, install them and see if the problem still exists...
Clear Corners and Sidemarkers
Old 03-16-2005, 12:41 PM   #7 (permalink)
ex owner/admin
Furious's Avatar
here is an idea to try, if you still have your old plugs put them back in and see if the problem occurs, another thing to check is that you connected the proper wires to the ignition coils.
anti seize is ok to use it wont kill anything, but its prefered not to use it. you could have been sold plugs that werent for your car, or maybe one is a dud.
Old 03-16-2005, 03:11 PM   #8 (permalink)
93 325i's Avatar
Antiseize should be used. I read that pelican parts article about electrical continuity and it doesn't affect performance one bit. You are actually running a risk by not using it. Our cars have aluminum blocks and you can easily strip the threads..If you want get a copper based antiseize for next time..
Complete mod list and pics:
My 1993 325i
Old 03-16-2005, 03:36 PM   #9 (permalink)
frank3 is an unknown quantity at this point
I agree w/furious...except, replace the old plugs one at a time. I'd bet you cracked the insulation on the new plugs when you installed them. By replacing one at a time, you can find out which plug is bad and then just replace that one.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 03-16-2005, 03:40 PM   #10 (permalink)
RIBEMR26's Avatar
Actually I think the risk in stripping the threads is greater on the way in...if the plug isn't lined up right...if you change your plugs when your supposed to every 10-15K, I dont see how it would be a problem....
Old 03-16-2005, 03:41 PM   #11 (permalink)
NGK's suck! other than that it sounds like you mixed up you wires, and ive never heard of putting any kind of gel on plugs before, sounds kinda stupid
Old 03-16-2005, 05:09 PM   #12 (permalink)
Thanks for the replys guys. I got it to start running pretty good. My freind that helped me his dad is a mechanic and we took it for a ride and it ran pretty good. he thinks it got some carbon in the engine when we replaced the plugs and just needs to work its way out. I think that i will take the NGK's back and get Bosch. to see if that will help. Again thanks for the replys
kris
Old 03-16-2005, 05:11 PM   #13 (permalink)
dont get bosch platinums cause they suck too, carbon in your engine huh? ok
Old 03-16-2005, 06:57 PM   #14 (permalink)
ok, then what is a good plug
Old 03-16-2005, 07:47 PM   #15 (permalink)
ex owner/admin
Furious's Avatar
both are fine dont listen to him, as long as they arent platinum +4s
