help with 318is... misfiring - BMW Forum - BimmerWerkz.com
Old 07-21-2006, 12:42 AM   #1 (permalink)
sabbath130 is an unknown quantity at this point
Exclamation help with 318is... misfiring
hello all, name is zack and havent been around in a while.
my 1996 318is m44 supercharged bmw has three check engine codes that i cannot fix.used: 1- random multiple misfire 2- cylinder two misfire 3- cylinder three misfire. on my boost gauge i am reading between 15-17.5 inches of helium at idle, believe a healthy engine SHOULD be approx 20.
i have taken multiple steps to try to fix the problem:
1- new coil pack
2- new spark plugs
3- new spark plug wires
4- new throttle position sensor
5- cleaned idle air speed control valve
6- checked for vacuum leaks.
7- replaced air injection hoses.
8- warm and cold compression test= never below 192 on ANY cylinder
sometimes when i go from in gear to rolling in neutral the rpm's will bounce before maintaining a steady idle speed. (the vacuum pressure bounces with the idle)
all in all... the car ran a 15.6 on the 1/4 mile (before a few of the fixes) and i spun all the way through first gear. car is drivable but definately holds back.
please help me becaue i am out of ideas.
sabbath130 is offline   Reply With Quote
Old 07-21-2006, 09:44 AM   #2 (permalink)
/Banned
preyash's Avatar
Car: Audi
preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash
Send a message via AIM to preyash Send a message via MSN to preyash Send a message via Yahoo to preyash
Hey wats up
I thought maybe i can help, i think its the ICV, i know u cleaned it but i would say just replace it. Try to use higer octane fuel in your maybe thats ur problem, when u changed ur spark plugs which ones did u use, if u used the high performance once u dont have to worry about gapping them but if u used the cheap ones u have to gap the plug point a few inches away from the spark center.l would say if one of your spark plugs fouled again u should check for that too, i would say that have all the things u replaced checked again... thats all thats comin upto my mind rite now, but if i think of something eles ill be sure to post it very soon...
Hope it helps
preyash
preyash is offline   Reply With Quote
Old 07-22-2006, 02:39 AM   #3 (permalink)
i used bosch +4 platinum plugs that require no gapping and i ALWAYS use premium gas if not sunoco 94 octane fuel.
<a href='http://www.putfile.com'><img border='0' src='http://x10.putfile.com/10/2840006249.jpg' alt='Hosted by Putfile.com'></a>
Old 07-24-2006, 12:42 AM   #4 (permalink)
From what I have heard you should avoid using Platinum plugs, buy OEM BMW plugs.
Need Opinions Asap On 318is For Sale! Hoody 3-Series (E21, E30) 4 08-26-2005 03:58 AM
Price For My 318is tagerman 3-Series (E36) 7 06-22-2005 04:30 PM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
318is vs. 325is 1985bmw325e 3-Series (E21, E30) 7 04-05-2004 09:17 PM
E30 318iS vs E36 318iS LondonE30-318iS 3-Series (E21, E30) 16 03-22-2004 01:32 PM
