| Sounds like either the clutch fan bearing or the clutch fan belt. Check the tension on the belts and make sure there are no rips along the teeth. Also, make sure you use only original BMW V-Belts, aftermarket ones sometimes will make horrible noises. Do not spray anything like "belt dressing" onto the belts, it only makes it louder and more brittle. If you get water or oil onto the belts, it will also makes really loud noises until it dries up.
Bry
<img src=" http://www.maxbimmer.com/forums/atta...tc=1"> |
