| Right, last night just finished work and was driving home, the car started making grinding noise's from the back, i stopped and smoke started pouring out then dissapeared, so i pulled off again and there was the constant grind so i had to leave it parked up, n e way had alook 2day and filled up the diff and the fluid started to come out almost straight away from the point where the prop shaft joins with the diff.
Does anyone know what has happened and what to do to fix it?
Cheers |
