help! - BMW Forum - BimmerWerkz.com
Old 04-03-2004, 04:41 AM   #1 (permalink)
VarakaCreamCraka's Avatar
VarakaCreamCraka is an unknown quantity at this point
I was crusing down the local high street last night, Then from hair buring heat from the feet fan, BAM it went cold. So i took it on the open road and ran it for abit but it did not heat up as much as normal.
This morning once the normal car temp was reached i tryed the fan it was warm but not hot as normal. (on max setting)
318is 1994
<img src='http://www.bmw-forums.com/forum/uploads/photo-5951.jpg' border='0' alt='user posted image' />
VarakaCreamCraka is offline   Reply With Quote
Old 04-03-2004, 02:00 PM   #2 (permalink)
When driving at about 60 mph the heat from the fan is alot warmer than if it was idling.
Old 04-03-2004, 02:30 PM   #3 (permalink)
Doogle325's Avatar
Doogle325 is an unknown quantity at this point
Send a message via AIM to Doogle325
I had the same problem with my 92. It seems to me that you need coolant. I was loosing the whole resouviour in abouy an hours worth of driving. I needed to change the h20 pump......Check your water level and go from there
Doogle325 is offline   Reply With Quote
Old 04-05-2004, 03:48 AM   #4 (permalink)
thx doogle im a bit of a noob when it come to engine bits, checked the coolant there was hardly any left. Took her for a spin let her cool down checked the coolant again it was gone toped it back up and it seems all cool now
Help! Help! Help! dvmotorsports 3-Series (E36) 6 06-02-2005 12:51 AM
Need Help! Car Is Barely Drivable komodo 3-Series (E36) 79 03-26-2005 10:41 AM
Help! My a/c will not turn on! jroberts312 3-Series (E36) 7 05-28-2004 03:30 PM
clutch master cylinder help! imprttuner88 3-Series (E21, E30) 1 02-05-2004 10:04 PM
2001-2003 M3 Steering. Need Help!? BMWPro77 3-Series (E46, E90) 6 01-31-2004 07:22 PM
