My E36 316i, overheats when drivig in city. If I let the engine running it starts to heat too much, but if I start driving, the engine returns to his ideal temperature. I've notest that the cooling fan that's atached to the engine is always runing, what about the fan behind the front bumber? It starts only when the AC is turned on or it helps the engine cool too? Sorry about my english but i think you understand my problem.
Thanks in advance!
the fan in front of the bumper is your auxilery fan it works in conjunction with the a/c, the clutch fan is connected to the engine..
i think you have a problem with the thermostat. id take it to get it changed
The aux fan should also come on periodically with or without the a/c, mainly when idling. Sounds like you have a faulty temp switch.
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
Where can I get a nose panel and grill like that? Portugal Only?
__________________ PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
Being that it cools down when you are moving, it appears to be an airflow issue. Your auxillary fan should kick on if it gets to a certain temp in the radiator.
The clutch fan alone can't pull enough air at times.
If the aux fan works with the ac on, try keeping the ac on, and seeing if it'll get hot at idle. If it does not, then I'd sudpect the temp switch, as Extech said.
