heater problem - BMW Forum - BimmerWerkz.com
Old 01-23-2004, 10:42 PM   #1 (permalink)
bmw_m3power's Avatar
bmw_m3power is an unknown quantity at this point
I can only turn my heater on 4, I can't use 1,2,3 if I turn it to 1,2,3 it will still be on but only blow small amount of heat. it suppost to be 2 is stronger than 1 and 3 is stronger than 2 and now 2 is not stronger then 1 and 3 is not stronger than 2 basiclly they are all equal now.
can anyone help.
I got 94 325is E36
bmw_m3power is offline   Reply With Quote
Old 01-24-2004, 01:15 AM   #2 (permalink)
TECH's Avatar
You need a new blower resistor. It should be on the driver side of the heater case, in the footwell area.
Old 01-24-2004, 09:34 PM   #3 (permalink)
can you please be more specific?
on the footwell area but where?
how do you change the blower resistor? is it complicated?
thanks
Heater Problem Bmmf40 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 11:38 PM
Heater Problem And Oil Problem floydzeppelinfan 3-Series (E36) 1 04-07-2005 10:19 PM
Need Some Help On Heater Control Unit Problem.. diehard_vue 5-Series (E12,E28, E34, E39, E60) 2 04-06-2005 08:17 PM
Need Help! Problem With Blower, Heater. DiRay 3-Series (E21, E30) 4 02-15-2005 04:13 PM
318IS heater problem jonniwal 3-Series (E36) 1 04-26-2004 12:37 AM
