| The air filter is next to the glove compartment. If you remove it (assuming left hand drive) then it is to the left of the glove compartment. It could also be the blower motor or a few other things.Note that on the air filter you do have to "break" the filter to put it in, meaning you do have to bend it along the "joints" before it will function correctly. |
