Heater - BMW Forum - BimmerWerkz.com
Old 04-01-2005, 05:44 PM   #1 (permalink)
christian is an unknown quantity at this point
My 1996 BMW 328is will not blow hot air while car sits in idle. The gas has to be applied in order for heat to function properly. It works fine while the gas is being applied. The temp. control unit has recently been replaced and a new radiator. Any ideas? Thank anybody for help.
christian is offline   Reply With Quote
Old 04-01-2005, 07:13 PM   #2 (permalink)
frank3 is an unknown quantity at this point
As I understand it, it's your heater control valve that needs replacing...it's sticking. But lets see how others weigh in on this.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 04-01-2005, 07:59 PM   #3 (permalink)
tdwyatt is an unknown quantity at this point
Especially in view of your recent replacement of the radiator, the more likely culprit will be insufficient bleeding of air out of the coolant system. Turn the heater on full hot, and re-bleed the system according to Bentley proceedure. This is a common symtom for inadequate bleeding.
HTH
tdwyatt is offline   Reply With Quote
Old 04-02-2005, 10:17 AM   #4 (permalink)
quality
Delmarco's Avatar
Also replace your microfilter? it's time hommie!
Old 04-02-2005, 12:03 PM   #5 (permalink)
Doogle325's Avatar
Doogle325 is an unknown quantity at this point
Send a message via AIM to Doogle325
add some coolant and see if that fixes the problem
Doogle325 is offline   Reply With Quote
Old 04-02-2005, 12:27 PM   #6 (permalink)
Duge is an unknown quantity at this point
guy, it's the thermostat man i had the same problem
and i'm a mechanic
Duge is offline   Reply With Quote
Old 04-02-2005, 01:53 PM   #7 (permalink)
and i'm a mechanic
[snapback]323847[/snapback]
Old 04-02-2005, 01:55 PM   #8 (permalink)
Originally posted by christian+Apr 2 2005, 03:53 PM--><div class='quotetop'>QUOTE(christian @ Apr 2 2005, 03:53 PM)</div><div class='quotemain'><!--QuoteBegin-Duge@Apr 2 2005, 02:27 PM
and i'm a mechanic
[snapback]323892[/snapback]
[/b][/quote]
Thanks for all the helpful info guys. This is great information.
Old 04-06-2005, 10:01 AM   #9 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
[quote=christian,Apr 2 2005, 02:55 PM]
Originally Posted by christian,Apr 2 2005, 03:53 PM
and i'm a mechanic
[snapback]323896[/snapback]
[/quot
if you have to put the foot on the gas to get heat, then most likely your water impeller is faling, dont forget the factory ones where made of plastic, check that too.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Heater Problems DKMassive 5-Series (E12,E28, E34, E39, E60) 0 07-06-2005 10:07 PM
Heater Problem Bmmf40 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 11:38 PM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
Interesting Heater Behavior hockey_fan 3-Series (E36) 6 11-03-2004 11:24 PM
Analog to Digital Heater Conversion Digital318is 3-Series (E36) 3 04-02-2004 01:34 AM
