Heated Seats Problem - BMW Forum - BimmerWerkz.com
Old 05-24-2006, 11:36 AM   #1 (permalink)
Pirtle 3 is on a distinguished road
my driver's side heated seat doesnt work. When i try to turn it on the light goes on for a couple seconds then turns itself off. This goes for the high or low setting. any ideas on fixing this problem? im hoping its just a fuse problem but perhaps its something in the wiring?
Pirtle 3 is offline   Reply With Quote
Old 05-24-2006, 11:46 AM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
my guess it is something in the seat heater itself is shorted (if it were a fuse it wouldn't work for a few seconds and turn off-it would work and then turn off perminantly until the fuse is changed)...the seat heater mats fail commonly enough
Come see me at MySpace
Old 05-24-2006, 12:05 PM   #3 (permalink)
but if it was the seat heater itself wouldnt the light stay on and the seat just wouldnt heat?
Old 05-24-2006, 01:04 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
yeah if the element fails the light should still stay on.. so if you hit the high setting does the seat heat up or not? it could just be the light, however thats the simple solution, the second and harder issue would be that the seat in fact does not heat up, than i would of couse check all fuses and than see if you can pinpoint if there is resistance (short) of sorts on the line thats causing the seat to fail.
Old 05-24-2006, 01:32 PM   #5 (permalink)
yeah it doesnt heat up at all, the light just turns off after a second and nothing happens, i will see what i can do and report my findings
Old 06-01-2006, 12:56 AM   #6 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
youre light turns of after a while becuase the resistor that heats up inside youre seat is gone, open circuit,
you need to order the heater pads that go inside the seat.
then dissaemble the seat and replace the heating pads.
it took me 2 hours, but now i got nicely warm heated seat.
you could use a multimeter to check for resistance accross the terminals of that come from the seat heating system.
if the pads circuit is open, then you will not read a resistance.
keep in mind that for the pads to fail after some years is common.
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 06-01-2006, 10:33 AM   #7 (permalink)
where do i buy one of these? do i have to go to the stealership?
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
1998 Bmw750il Heated Steering Wheel Problem Willb395 1,6,7,8 - Series and Mini Cooper 3 07-12-2005 08:43 AM
Heated Seat And Tail Light Problem MadBMW M-Series (M1, M3, M5, M6) 1 03-17-2005 08:54 PM
Fs: Cloth Heated Seats connor014 Classifieds Sell & Buy 0 10-10-2004 04:26 PM
How to tell heated seats out of car? Brian330i 3-Series (E46, E90) 0 10-26-2003 10:54 AM
