Headlight problem: City lights don't work (low and high beam do) for some reason my city lights don't work.
if i put the headlights on to that setting (the first click on the headlight control) all the headlights stay blank even though the dash lights work fine.
if i put the headlight control on the second setting (low beam) that works fine, as well as if i pull back the indicator stick for high beam.
what could this be?
thanks to cruzin 323i, i check the wiring and that seems fine. the bulbs are ok too, same as the fuses.
how do the city lights work? is a smaller wattage or current passed through the bulbs? i assume it must be as when on high beam the bulbs light up fully
please help!!! |
