Headlight Mounting.. - BMW Forum - BimmerWerkz.com
Old 01-18-2005, 10:03 PM   #1 (permalink)
Cloxe is an unknown quantity at this point
Yeah i've got a 1994 318i and before i bought it the person who owned it much have hit something on the drivers side but the front quarter pannel is kinda dented and the plastic mounting for the headlight is cracked making the light lean downwards and shake while driving.. Just curious if there is a poxie or something i can put on the plastic to make it hold or do i need to replace the full mounting.
Cloxe is offline   Reply With Quote
Old 01-19-2005, 01:43 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
is the mounting broken? have you given it a look, you can also try to tighten it if its possible.
Old 01-19-2005, 06:40 AM   #3 (permalink)
ganjacyde is an unknown quantity at this point
Send a message via AIM to ganjacyde Send a message via MSN to ganjacyde
looks like your hood and fender are a little bent...might wanna go to a body shop and have them pull that out for you.
<embed src="http://www.svcountryclub.com/upload/e36m42.swf" width="420" height="140" background="none" menu="false">
ganjacyde is offline   Reply With Quote
Old 01-19-2005, 09:25 AM   #4 (permalink)
komodo's Avatar
komodo is an unknown quantity at this point
Yeah, I'd get the hood straightened out first. For the headlight assembly on your car, there's 4 bolts to hold it in, and if one's not securely tightened down, it will not hold correctly. (Talking about hte right headlight assembly) There's two bolts up top, one on the right side behind the side marker, and one on the bottom left of it in the back. You might have to take off that plastic cover for the ram air intake for the alternator to be able to get a tool straight down to get the bolt. They each serve a purpose, for example the right bolt behind the corner acts as a tilt forward and backward, holding the light flush with the bottom. The hard-to-reach one in the back holds the light horizontally secure, flush to the left.
I'd first test which way the light moves and then throughly inspect the bolt holding it for that movement. If all 4 of those are secure, the light should not move at all.
Just something else to look into.
komodo is offline   Reply With Quote
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
I Need A Headlight Prism Or Headlight 528man Classifieds Sell & Buy 0 04-06-2005 09:37 PM
FS: Z3 Headlight, M3 side skirt, Clear sidemarker nite_boy Classifieds Sell & Buy 2 09-24-2004 10:39 AM
Headlight aiming help mrogers 5-Series (E12,E28, E34, E39, E60) 7 03-29-2004 05:25 PM
What are headlight eye lids acousticvan 3-Series (E36) 4 09-27-2003 08:37 AM
