Headlight Issues - BMW Forum - BimmerWerkz.com
Old 05-17-2005, 08:30 AM   #1 (permalink)
dragoncnc is an unknown quantity at this point
I am having problems with my headlights staying on after I turn the switch off. I have daytime running lights on a 1996 318is, and I am not sure if it is the light switch or daytime running light module. Sometimes the highbeams will work, sometimes they won't. Has anyone run into a problem like this?
dragoncnc is offline   Reply With Quote
Old 05-17-2005, 08:49 AM   #2 (permalink)
e36surge's Avatar
I am having the same problem. See the atached pic.
Open your fuse box behind the driver side shock tower (under hood). I've highlighted the green relay, this is probably your problem.
To verify, start your car, turn on the lights, Turn off your car and turn off the lights... if they stay on, tap the relay I've highlighted with the back end of a screwdriver (not too hard). The lights should go off.
Solution... replace it... I'm going today to pick mine up.
Let us know if it works.
Old 05-17-2005, 09:25 AM   #3 (permalink)
I tried tapping the relay a few times and every time it worked. Thank you very much for your help!! I will order new one today
Old 05-17-2005, 10:11 AM   #4 (permalink)
93 325i's Avatar
Is this a canadian thing???? j/k nice work surge
Complete mod list and pics:
My 1993 325i
Old 05-17-2005, 10:31 AM   #5 (permalink)
e36surge's Avatar
It probably is... the winters up here are very cold, very dry and depending on where you live the road crews use rock salt to help drivers keep traction... the calcium wreaks havoc on everything electrical... not to mention your paint... the relays do fail with time... mine failed after ten years and of all days for it to fail... the day I bought her...
Just doing my part.
Fuel issues? Car bogging! ReaverJam 3-Series (E21, E30) 5 10-04-2005 10:16 PM
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
I Need A Headlight Prism Or Headlight 528man Classifieds Sell & Buy 0 04-06-2005 09:37 PM
Headlight aiming help mrogers 5-Series (E12,E28, E34, E39, E60) 7 03-29-2004 05:25 PM
What are headlight eye lids acousticvan 3-Series (E36) 4 09-27-2003 08:37 AM
