Originally posted by Furious@Jan 25 2005, 03:36 AM off topic question, which angel eyes did you get? (like are they lightning plus or enhanced?) [snapback]278692[/snapback] |
changing the fuses to higher amps will only make the electrical system vunerable to electrical shorts.
if the light where sucking too much power, the fuse would have blown up..
what is most likely the cause of your problem, is dirty contacts that led to electrical resistance, therefore lower voltage.
then see what are the components that light the angel lighs made off.
if they use the cheap LED lights,. then you wont get much brightness.
have a good one.
