head swaps - BMW Forum - BimmerWerkz.com
Old 08-05-2004, 10:09 PM   #1 (permalink)
astral_tx is an unknown quantity at this point
ok well, im still new to the bmw engines, but i see alot of bitching on the forums about lack of power but also lack of money or ideas to make it faster haha. ok well if someone could follow up on this with engine codes and match for model and year, and i will investigate a little bit on whether or not head swapping might be for you. a head swap from a higher output motor to an identical or similar block might give better compression, thus giving more horsepower. some things you guys might want to try besides your intakes and cams, and haha....haha.. exhaust. try milling the deck. its a little expensive but it can prove to get better compressions and thus higher horsepower. this is not generally recomended unless you are really serious about squeezing power, but it will work maybe. but yea, someone give me some motor codes and what you ARE POSITIVE about on identical blocks in different cars. i might be able to do some searching, and come up with a chart of what you can swap onto what. im pretty sure this can be done with something, its not uncommon. think chevy and ford guys always swapping heads to different size engines etc. so, motor codes and models please!
astral_tx is offline   Reply With Quote
Old 08-05-2004, 10:52 PM   #2 (permalink)
Kevin325i's Avatar
6 cylinder goes 6 cylinder(m50 m52 s50 s52). 4 goes 4. m 40 m44 (not sure on those)
I'm sure you're more concerned with the 4 bangers. Autotechnica knows all about them. The 6s are more my specialty.
Kevin (President TBEA)
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
CD changer compatibility with aftermarket Head Unit Teh Prof Audio and Electronics 2 11-07-2005 05:22 AM
OEM changer and head unit mystery BobCT Audio and Electronics 4 08-04-2004 11:50 AM
Pulling the head llll1l1ll 3-Series (E21, E30) 2 04-09-2004 11:43 PM
