Head Liner - BMW Forum - BimmerWerkz.com
Old 05-04-2005, 03:00 PM   #1 (permalink)
morristhecoolcat is an unknown quantity at this point
Send a message via AIM to morristhecoolcat Send a message via Yahoo to morristhecoolcat
Hey all, need some help. Having a ratling noise on my 94 318I? Seems like when I hold the head liner up with my hand the noise goes away! Any way to tighten up screws in liner or roof?? Any suggestions?? [B]
Thanks
morristhecoolcat is offline   Reply With Quote
Old 05-05-2005, 02:30 AM   #2 (permalink)
mike_e36's Avatar
mike_e36 is an unknown quantity at this point
hey, the only screws that are holding the headliner in place are that of the "oh-shit-handles", the sunvisors, and the sunvisor grounds, they are all phillips head screws. if your lights don't come on in the back of the sunvisor where the mirror is, it could also be a loose ground rattling around. or if you have a sunroof, is could be a loose connection. another quite possible culprit could be a little plastic snap in part to hold wires to your center light poped out. you can always take off your front or back pillers (they pop off with a little pull), unscrew anything (sunvisor or handle) and just take a look, the screwdriver should even be in your BMW toolkit in the trunk, and should take around 10 minutes. have fun, good luck, hope it stops rattling, i hate rattles.
mike_e36 is offline   Reply With Quote
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
removing head liner ? j123crx 3-Series (E21, E30) 7 09-15-2005 08:10 PM
Head Liner -pimpin328is- 3-Series (E36) 3 03-01-2005 04:35 PM
OEM changer and head unit mystery BobCT Audio and Electronics 4 08-04-2004 11:50 AM
