Head Gasket replacement - BMW Forum - BimmerWerkz.com
Old 12-30-2011, 09:40 AM   #1 (permalink)
Car: 2.5 litre 323i convertable 1999
clivevfr is on a distinguished road
Angry Head Gasket replacement
hi all,
i have to replace the head gasket on my 323i. i have stripped the head and removed head bolts, how do i remove the head from the cylinder block with out causing damage as it won't budge. any advice would be appreciated.
clivevfr is offline   Reply With Quote
Old 12-30-2011, 09:45 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Have you disconnected the timing-chain? If yes and everything else is disconnected, then it just simply might be stuck to the gasket... Might be easier to lift/prise off using the manifold !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 12-30-2011, 10:00 AM   #3 (permalink)
secondry timing chain removed and primary chain ddisconnected. i thoght it might just be bonded to the gasket and am just worried in case i damge the gasket face when removing it seems to be solidly fixed.
Old 12-30-2011, 10:04 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
It will be on locating dowels too, tap it with a rubber mallet or a block of wood/hammer (not too hard mate !!
Eso es todo!
BMW Part Market
New Member ?
Old 12-30-2011, 10:13 AM   #5 (permalink)
Talking
thanks for that, i'll let you the result tomorrow.
Old 12-30-2011, 10:15 AM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Have a friend nearby dude, might be a tad heavy !
Eso es todo!
BMW Part Market
New Member ?
Old 12-31-2011, 08:35 AM   #7 (permalink)
Car: 1994 E36 318I
Frozen 318i is on a distinguished road
Exhaust Manifold
I am sure you no you have to disconnect the Manifold from exhaust system! the exhaust is heavy, or you can remove the manifold from the head before you lift will save you a lot of weight. If you disconnect the exhaust from the manifold then get under the car and push the manifold up and down not too hard it should loosen or grab one side and tug. Just in case make sure you have all the bolts out look at nearest fire wall side of the head after the valve train.
Frozen 318i is offline   Reply With Quote
Old 01-05-2012, 10:39 AM   #8 (permalink)
Thumbs up
thanks for that. worked a treat. now the labourious task of puuting it all back together.
Head Gasket Replacement Rainman66 3-Series (E21, E30) 3 01-09-2013 08:24 PM
Head Gasket Replacement On A 96 328 spfdfanatic 3-Series (E36) 23 01-09-2013 08:17 PM
'94 Head Gasket Replacement ricks5series 5-Series (E12,E28, E34, E39, E60) 2 02-03-2011 07:57 PM
head gasket replacement polska 3-Series (E21, E30) 3 01-12-2010 10:12 AM
head gasket replacement RKramden 3-Series (E36) 6 02-17-2009 06:50 AM
