Hazard help - they arent working! - BMW Forum - BimmerWerkz.com
Old 05-26-2009, 09:07 AM   #1 (permalink)
Car: 2006 E90 325i
Jog5000 is an unknown quantity at this point
Well, my hazards dont work when I push in the hazard button. My indicators work fine. I've swapped my hazard button with a buddies, same story, and my button works in his car.
Could it be the relay that is shagged? There is power coming to the button in the console.
Jog5000 is offline   Reply With Quote
Old 05-26-2009, 09:11 AM   #2 (permalink)
I think you're on the right track. Might as well have a look at the fuses, but I think you may find an actual wire issue.
Old 05-26-2009, 09:23 AM   #3 (permalink)
Car: 2006 E90 325i
Checked all the fuses too, swapped a whole lot, just to be sure, same story, still dont work.... When I turn on the lights (headlights etc), the hazard button does light up, as it should (it stays glowing red).
Old 05-26-2009, 08:45 PM   #4 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Locate the flasher unit, it will be similar to the one for the directionals but maybe larger. Follow the clicking.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 05-28-2009, 09:21 PM   #5 (permalink)
Car: 1997 328i
talon11 is on a distinguished road
I am having the same problem and more if you find out what wrong let me know i have tried most things and nothing has worked
talon11 is offline   Reply With Quote
Old 06-13-2009, 03:27 PM   #6 (permalink)
Car: 2006 E90 325i
Ok, so I sorted out my problem - there is a relay behind the glove box - mine was a bit loose, wiggled it around a bit, and it worked perfectly. Note that my car is a RHD, so not sure if the relay is behind the glove box or steering wheel of a LHD car...
Old 06-13-2009, 03:30 PM   #7 (permalink)
Interesting, glad you got it sorted - thanks for updating everyone!
Hazard Lights slick200201 3-Series (E36) 0 07-11-2004 12:22 PM
Hazard lights napa218 3-Series (E36) 2 04-27-2004 01:50 PM
headlights arent working... JeremyMarkham 3-Series (E36) 5 01-24-2004 02:00 PM
most cleaning products arent so good sakuramboo Wash & Detail 2 12-09-2003 03:16 PM
hazard flashers pittisus 3-Series (E36) 7 10-16-2003 05:11 PM
