Guibo Install - BMW Forum - BimmerWerkz.com
Old 11-28-2004, 05:46 PM   #1 (permalink)
325is1994 is an unknown quantity at this point
how hard is it and about how long does it take? how much should a mechanic charge? should i just do it myself?
<a href='http://img136.exs.cx/my.php?loc=img136&image=bmwcopy3kb.gif' target='_blank'><img src='http://img136.exs.cx:81/img136/8032/bmwcopy3kb.th.gif' border='0' alt='user posted image' /></a>
mods: intake, m3 exhaust, chip, carbon fiber hood and emblems, clear corners, reverse indiglo gauges
stereo: panasonic touch screen, polk component set in q logic kick panels, kicker 5 channel amp, 12&quot; kicker square
325is1994 is offline   Reply With Quote
Old 11-28-2004, 05:49 PM   #2 (permalink)
B3M2W5i's Avatar
B3M2W5i is an unknown quantity at this point
Send a message via AIM to B3M2W5i
what is a guibo?
Cashmere Beige Metallic
B3M2W5i is offline   Reply With Quote
Old 11-28-2004, 06:20 PM   #3 (permalink)
it's also called the flex disc. It's a urethane bushing that mounts to the rear drive shaft. It absorbs vibrations and gives the car a smoother ride.
I haven't replaced mine yet, so I can't say from experiance how long it should take. I've heard it's not to bad and takes a couple of hours. I've seen a DIY some wheres. Check the FAQs section.
Old 11-28-2004, 06:22 PM   #4 (permalink)
3serbmdubya is an unknown quantity at this point
its not that hard
1 jack up the car
2 remove exhaust
3 remove heat shields
4 remove drive shaft
5 remove guibo bolts [you will need someone to put tranny in gear and take it out for each bolt so you can reach it]
6 install new one
7 put everything back
diy here
http://www.pelicanparts.com/bmw/techarticl...o/E36-Guibo.htm
<img src='http://img73.exs.cx/img73/8618/post-4-1069548360.jpg' border='0' alt='user posted image' />
3serbmdubya is offline   Reply With Quote
Old 11-28-2004, 06:22 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
There is a write up on it at pelicanparts.com Go under tech articles.. and should find it.. its there...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-28-2004, 06:40 PM   #6 (permalink)
supark is an unknown quantity at this point
is your guibo cracked? It's really something that you don't change as a regular maintenance.
supark is offline   Reply With Quote
Old 11-28-2004, 07:08 PM   #7 (permalink)
350z
Car: 03 Nissan 350z Track
man that write up seems fun... haha
David
**BAKER POW REPORT**
Old 11-28-2004, 07:55 PM   #8 (permalink)
Kevin325i's Avatar
It's fairly easy, but you'll need two 17mm(i think don't quote me on it) open end wrenches because of clearance issues.
Hardest part will be getting the exhaust off so spray some liquid wrench or pb on the 6 nuts for a few days before you do it.
Kevin (President TBEA)
Old 11-28-2004, 09:20 PM   #9 (permalink)
94 325is's Avatar
94 325is is an unknown quantity at this point
Send a message via AIM to 94 325is
did mine a couple of months ago. didnt have to drop the exhaust just the drive shaft, which is no big deal. took me about three hours but i was having to put it in and out of gear myself.
94 325is is offline   Reply With Quote
Old 11-28-2004, 10:41 PM   #10 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
kevin, very close, its 18mm. thats a good memory though, i just remember cleary because when we were doing it my brother actually had to go and buy a whole seperate 18mm wrench
xsperf is offline   Reply With Quote
Old 11-28-2004, 11:42 PM   #11 (permalink)
[snapback]239188[/snapback]
So you only dropped the exhaust and didn't remove any other components? I'm actually change out the output shaft seal along with the guibo and I've been holding it off because the amount of time it would take to remove the exhaust, heat shield, etc.
Old 11-29-2004, 10:42 AM   #12 (permalink)
my mechanic said it would be 150 to change it, im thinking about just paying it
Old 11-29-2004, 04:11 PM   #13 (permalink)
Kevin325i's Avatar
[snapback]239238[/snapback]
Bah, I knew I was close. My friend and I had just started the second day of working on my clutch at about 6am and we realized we didn't have the wrench to take the driveshaft off. We ended up having to wait for the hardware store to open to pick one up.
Amp Install And Amp Suggestions grant862 Audio and Electronics 2 08-07-2005 07:36 AM
Want To Install Xm Or Sirus In My 530i Jeffrey262 5-Series (E12,E28, E34, E39, E60) 1 03-10-2005 03:30 PM
Ipod / Icelink Install W/ Photos - Concealed Ashtr WindowPro Audio and Electronics 0 12-29-2004 12:06 PM
HEADLIGHT/DDE INSTALL? kraze0g 3-Series (E36) 3 08-19-2004 07:47 PM
Another E39 aftermarket H/U install.....SOS! Endangered Beatz Audio and Electronics 6 05-31-2004 10:26 PM
