Guibo.. Hard to change??? - BMW Forum - BimmerWerkz.com
Old 04-08-2008, 01:48 PM   #1 (permalink)
Paulie325is is on a distinguished road
hey guys since ive had the car i havn't changed the Guibo.. i was just wondering if it was that hard to replace.. Thanks for all your help!! paulie325is
Paulie325is is offline   Reply With Quote
Old 04-08-2008, 02:29 PM   #2 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
mot hard, ill link u when i get home..
Old 04-09-2008, 01:35 PM   #3 (permalink)
K Thanks a lot !!
Old 04-09-2008, 01:46 PM   #4 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
First make sure you need to. Is it cracked?
Lindsay fan club member.
Old 04-09-2008, 10:55 PM   #5 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
I've done guibo's, and center support bearings on a few BMW's. Shoot some penetrating fluid on the exhaust bolts, I did that as some of the bolts and studs looked like they would be easy to snap. If you do have a buddy that could help you it would save time when you have to spin the driveshaft and put it in gear, or put on the handbrake to lock it each time to get 2 bolts you couldn't reach before. Also can be helpful to have them help you undo the bolts, as you need an extension on one side of the guibo bolts to undo them or your ratchet will hit the driveshaft and not fit on properly, and holding a wrench and a ratchet with an extension on it on usually very stiff bolts isn't fun.. Don't forget to shoot penetrating fluid on the guibo bolts too.
good luck
Old 04-09-2008, 11:01 PM   #6 (permalink)
Dosn't sound that hard
Thanks a lot guys for the info it should all come in handy when i try to do it!!! Thanks again!!
Guibo Help 180kbim325 3-Series (E36) 4 07-12-2005 04:48 PM
How Hard Is It To Change The Timing Belt sexydylan05 3-Series (E21, E30) 5 04-30-2005 12:45 AM
Hard Or Expensive To Change Front Bumper? tyro2001 3-Series (E21, E30) 3 02-03-2005 12:02 AM
Guibo flying_junk 3-Series (E36) 4 12-14-2004 05:52 PM
New guibo Kevin325i 3-Series (E36) 19 07-26-2004 01:40 PM
