Ground Control coils came in, I have a question... - BMW Forum - BimmerWerkz.com
Old 12-05-2003, 06:07 AM   #1 (permalink)
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
My coilovers say on the outside of the box that they are for a 92-99 e36 m3 with stock konis..I have a 1992 e36 325i..I know that m3 suspension will fit my car so I am assuming that these coils will fit with no problems..
Also, it says that I have to cut my front and rear bumpstops to get the desired height and handling...Is this ok to do? Thanks for any help, they are going on tomorrow night, I will let ya'll know how it goes...
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline   Reply With Quote
Old 12-05-2003, 06:51 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
well see the problem with getting different springs than what is recomended for your car is that its set up to accomodate that particular car, Yes the M3 suspension will fit, i sort of have it (well its called Mtech suspension) but my car originally was bought from the dealer as such. in this case i think youll be fine, there really isnt much of a difference between the two cars. sounds like youll be just fine
Old 12-05-2003, 09:30 AM   #3 (permalink)
Fissionx's Avatar
Fissionx is an unknown quantity at this point
If you bought the coilover kit it should come with the struts/shocks and the springs. What all did you buy. GC CO's do not use "stock konis"
You shouldn't need to cut bumpstops on Konis.
-Dan
Turbo 328
<img src="http://www.bmw-forums.com/forum/inde...2858">
Fissionx is offline   Reply With Quote
Old 12-05-2003, 10:05 AM   #4 (permalink)
Scarface's Avatar
I bought the Ground Control coilovers without the shocks..I have Bilstein on there now but I will change the shocks out later with some to go better with the coilovers. Maybe I should try the setup first without cutting the bumpstops? If it still sits up higher then I will resort to cutting them.
Question About Coils? jrhaile 3-Series (E36) 0 10-13-2004 10:05 PM
climate control question RedlinedRU 3-Series (E36) 2 09-20-2004 11:09 AM
General Control Module question wilkie3 5-Series (E12,E28, E34, E39, E60) 0 08-04-2004 11:27 AM
325is Traction Control Question tico481 3-Series (E36) 5 04-10-2004 10:05 AM
