glorious oil leaks!!!!!!help please - BMW Forum - BimmerWerkz.com
post #1 of 21 (permalink) Old 09-02-2008, 01:47 PM Thread Starter
hunter325i's Avatar
hunter325i is on a distinguished road
ok so im trying to fix a vacuum line problem i had two days ago and i get everything put back onto the engine and start it up and low and behold she starts up!!! sweet right, WRONG, i let it run for a cool 30-40 secs when my father inlaw says whats under your car, i look and its a thin steady stream of oil ...YES!!!! so i turn off the car and traced it oil to the highest point till i dont see any more, and it stops around a bolt just below and behind the oil filter...WTF is going on, i fix one thing and the whole car is falling apart.
hunter325i is offline
post #2 of 21 (permalink) Old 09-02-2008, 02:51 PM Thread Starter
hunter325i's Avatar
pics, maybe that will help
ok so i found my little leak...well big leak ...ok so i looked at my bently man...and i found a view of the oil filter housing
My engine doesnt have the connection for that tube coming down on the top middle and thats where my engine is leaking oil, would there be a stock plug??? and can i get to the plug from the inside of the oil filter housing...
MOAR pics
green=oil filter housing
blue=alt
red is where that connection would have been made, but its leaking there
red is where its leaking...i cleaned it up a bit, but it really startes to spit when there is pressure....
i hope the pics are helping
post #3 of 21 (permalink) Old 09-02-2008, 06:28 PM Thread Starter
hunter325i's Avatar
20 views and not even an IDK.......
post #4 of 21 (permalink) Old 09-02-2008, 11:53 PM
my car is red
94BMW325i's Avatar
94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of
could very well be from the oil filter housing. I had a REALLY bad oil leak from there a while ago.
94BMW325i is offline
post #5 of 21 (permalink) Old 09-03-2008, 12:11 AM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute
Go to realoem.com and navigate to the oil filter housing section of the parts catalog for your car. You can retrieve the part number from tehre and buy it online. If the usual suspects (pelican parts, bavauto, etc.) don't stock it, I am sure yu ca special order it, or even just get it from -- gulp -- the dealership.
Good luck.
drz is offline
post #6 of 21 (permalink) Old 09-04-2008, 01:25 PM Thread Starter
hunter325i's Avatar
but did you know where your leak was coming from???
post #7 of 21 (permalink) Old 09-04-2008, 08:17 PM
my car is red
94BMW325i's Avatar
it was from there, and the valve cover.
post #8 of 21 (permalink) Old 09-04-2008, 11:40 PM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
If you ask me, it looks like something is missing in the area of those red arrows. A cap or plug. I am going to look at my car tomorrow & I will get back to you.....
johnny,
____________________________________________
johnnyBgood is offline
post #9 of 21 (permalink) Old 09-05-2008, 12:25 AM
my car is red
94BMW325i's Avatar
hunter check out realoem.com for your car. They have really good diagrams.
post #10 of 21 (permalink) Old 11-02-2008, 09:01 PM
LeonL is on a distinguished road
I am not sure if you have fixed your oil leaks issue. For the past few months, I have had oil leaks issue. I have replaced what is obvious, but there are still oil leaks from different locations. I have replaced the complete valve cover gasket. Also, I have recently replace oil pan gasket. While I was working on the oil pan gasket, I saw there are some oil leaks from above. I think it is where your pictures shown. I too suspect that the oil filter housing gasket could be the issue. Did you fix or replace the gasket?
Thanks.
LeonL is offline
post #11 of 21 (permalink) Old 11-22-2008, 10:09 PM
325iS's Avatar
325iS is an unknown quantity at this point
There are two o-rings sealing off the ports on the back of the oil filter housing. They get hard with age and can start a major oil leak quickly. I had the same oil leak a few weeks ago and just replaced mine... the ground beneath my car stays dry as a bone now.
I took some pictures. I'll try to take some time and get them off the camera and post them here.
-Brian-
- - - 11.56 @ 120 - - - 410 rwhp / 459 rwtq (Naturally Aspirated)
Hell yeah, it's a street car!
'92 325iS - - - - - - - - - 15.328 @ 89.70
325iS is offline
post #12 of 21 (permalink) Old 11-23-2008, 11:00 AM
Help from over the pond
marti5's Avatar
You should be able to buy a box of different size 'o' rings from a good plumbing merchants, so far touch wood, when I have an 'o' ring fail theres always one that fits in the box full I have.
marti5 is offline
post #13 of 21 (permalink) Old 11-23-2008, 03:06 PM
325iS's Avatar
When you change the o-rings, I would recommend removing the entire oil filter housing for two reasons. One is because it is a lot easier to access the two ports with it off of the engine. The second reason is because then you can also replace the oil filter housing gasket which is probably also on it's way to becoming a problem.
Removing the housing is not too difficult and only involves renmoving the alternator, and dropping the power steering pump down out of the way. After that, there are only six bolts holding the filter housing to the block.
Here are some pictures of what is likely leaking on your car:
You can see the two ports on the back with the plugs in place. The upper port is what your red arrows are pointing to.
Once the retaining rings are removed, the plugs can be drawn out of the ports. Here's what it looks like with them removed:
Here is the underside of the housing that fits to the block. I also show the plugs, o-rings, retaining rings, and filter housing gasket laid out in front:
Here is a close-up of the plug, o-ring, and retaining ring:
Hope this helps out.
-Brian-
325iS is offline
post #14 of 21 (permalink) Old 11-23-2008, 03:11 PM
marti5's Avatar
Superb photos, I must say, hope this helps out Hunter 325i, well done.
marti5 is offline
post #15 of 21 (permalink) Old 11-23-2008, 03:20 PM
325iS's Avatar
Well, even if he has already fixed his problem, hopefully these will help other people in the future. I too was trying to figure this issue out recently and couldn't find any good pics of what was wrong. When I fianlly got to the problem, I decided to take the pics in order to help others down the road.
-Brian-
325iS is offline
The glorious sound of the almighty m30 WALSRU Video Vault 20 11-05-2007 09:08 PM
New Waterpump Leaks Laker 3-Series (E36) 4 09-02-2005 08:18 AM
Oil Leaks? Any Way To Fix Them BMW-ATI 3-Series (E36) 25 04-27-2005 01:45 PM
Oil Filter Leaks? tyro2001 3-Series (E21, E30) 4 03-21-2005 06:47 PM
