gears and clutch - BMW Forum - BimmerWerkz.com
Old 02-05-2009, 02:49 PM   #1 (permalink)
Car: 1997 328i touring
dudehog is on a distinguished road
gears and clutch
hi everyone. i have an issue. in the past two days i have found it hard to engage gears. especially from cold into first and reverse. the clutch doesn't seem worn out. i've driven at 30mph in 2nd/3rd/4th and 5th gear and accelerated and there is no slipping.
does anyone know what this could be? where can i find the resevoir for the hydraulic fluid for the slave cylinder and where is this too. thanks. john.
dudehog is offline   Reply With Quote
Old 02-05-2009, 03:06 PM   #2 (permalink)
martyyyn's Avatar
Car: E36 325Turbo Diesel
martyyyn is on a distinguished road
Probably the slave cylinder
Pelican Technical Article: BMW Clutch Slave Cylinder Replacement
good luck Martin
martyyyn is offline   Reply With Quote
Old 02-05-2009, 06:48 PM   #3 (permalink)
mheidemanjr's Avatar
Car: 1994 bmw 318i
mheidemanjr is on a distinguished road
Send a message via AIM to mheidemanjr
good luck Martin
agreed slave cylinder
mheidemanjr is offline   Reply With Quote
Old 02-07-2009, 03:15 PM   #4 (permalink)
well the plot thickens. did a test on the slave. and bmw said it was fine too. so the next plan is to change the clutch. will keep you all posted.
Shifting Gears goodespeler 3-Series (E21, E30) 16 02-23-2005 05:59 PM
Changing gears without clutch ? Q_BMW 3-Series (E36) 35 07-01-2004 10:06 AM
Winding the gears 318i-Bmw 3-Series (E36) 3 09-24-2003 09:39 PM
