Gear box swap - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 12-26-2008, 11:17 AM Thread Starter
kontaktsounds is on a distinguished road
Gear box swap
How hard is it for a straight gear box swap on a '98' 318is ?
I know the bell housing is very close to the bulkhead will this cause a problem?
Will this be easy enough using a ramp?
Tips please,
Thanks
kontaktsounds is offline
post #2 of 3 (permalink) Old 12-26-2008, 12:56 PM
my car is red
94BMW325i's Avatar
94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of
Is it a manual gearbox, and you are using the same model? I would definetely try to get the car higher than ramps, I had my car pretty much as high as the jackstands would go. Also back off the top nuts on the engine mounts, and undo the trans brace with the 2 bushings on it. Will give you a lot more room. The bolts aren't too hard to get to, and see if your starter has nuts behind it, if you do get a wrench on them or they will just spin most likely..
I know that's kind of cluttered, but I did mine not that long ago, so let me know if you need any specifics.
94BMW325i is offline
post #3 of 3 (permalink) Old 01-02-2009, 10:43 AM Thread Starter
When i said ramps i meant a four post or something similar. The box is from a 318 bout the same age, but mines a 318is and they have the same box. They (3 series E36) were mostly fitted with only two different box's apart from the M3 so i know ive got the right match, should be ok.
If i get stuck ill give you a shout thanks for your help.
E34 Zf gear box swap plug difference beelzebubs FAQ's and DIY's 0 06-03-2008 08:42 AM
Refilling Gear Box Oil mmclaren 3-Series (E36) 4 05-21-2005 05:06 AM
Problems With Gear Box geoff 5-Series (E12,E28, E34, E39, E60) 4 10-12-2004 01:45 AM
Second Switch of gear box maceno 3-Series (E21, E30) 0 09-07-2004 08:14 AM
Need help with auto Gear box SweetflavaUK 3-Series (E21, E30) 0 09-02-2004 07:42 AM
