Gauge Cluster Light Burnt Out - BMW Forum - BimmerWerkz.com
Old 02-16-2005, 08:30 PM   #1 (permalink)
Silverstreak is an unknown quantity at this point
Hi one of the lights that lights the gauge cluster has burned out. It is noticeable at night time and I would like to replace it... Is it easy to take the gauge cluster out and is the light a LED or regular filament bulb?
Thanks
<a href='http://www.cardomain.com/memberpage/237652' target='_blank'><img src='http://img170.exs.cx/img170/5774/sig2uq.jpg' border='0' alt='user posted image' /></a>
Mods: M50 intake manifold, BFP CAI, Fan delete, CDV delete, Clears all around, M contours, Clutch stop, Debaffled exhaust, CF BMW emblems
Silverstreak is offline   Reply With Quote
Old 02-17-2005, 11:41 AM   #2 (permalink)
pcy
pcy is an unknown quantity at this point
[snapback]293298[/snapback]
It's small filament type bulb. Very tiny bulb.
The bulb is available at the dealer for $2 or so. It's relatively easy to access behind the cluster. Search for "cluster" in the discussion boards" for the procedure. If you have tilt steering wheel, it'll make the job easier. If you don't have tilt wheen, then center the steering wheel before you start taking the screws for the cluster. You don't have to take the cluster out completely. Once you can see the behind of the cluster, you will see the bulbs.
Good Luck
pcy is offline   Reply With Quote
Old 02-19-2005, 12:03 AM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
I replaced all my bulbs last weekend (preventive maintenance) whilst putting in gauge rings. You need three, and it should take you less than an hour. Here's a DIY I used, it explains it well enough....{CLICK HERE}
It turned out ok, I guess....
Old 02-19-2005, 12:23 AM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
Originally posted by jllphan@Feb 19 2005, 01:03 AM
I replaced all my bulbs last weekend (preventive maintenance) whilst putting in guage rings. You need three, and it should take you less than an hour. Here's a DIY I used, it explains it well enough....{CLICK HERE}
[snapback]294693[/snapback]
that looks phat!! imma do that!
-SOLD..
R.I.P Fast 6
Diy: Gauge Cluster Light Delete ///M Power 5-Series (E12,E28, E34, E39, E60) 11 08-10-2005 09:23 AM
Removing Gauge Cluster exjarhead328 3-Series (E46, E90) 1 03-10-2005 02:22 PM
Help! A Very Headache Gauge Light Problem shuiyuan 3-Series (E36) 3 12-18-2004 09:25 PM
Gauge Cluster Problem BMWGuy325i 3-Series (E36) 4 04-25-2004 10:34 PM
