Gas Fumes Inside - BMW Forum - BimmerWerkz.com
Old 07-14-2005, 09:45 PM   #1 (permalink)
ac_iconn555's Avatar
ac_iconn555 is an unknown quantity at this point
What is wrong with my car.. or what do I need to replace if:
After I fill up on gas.. I smell a strong fumes odor inside my car for the next day or so.. Have you had this problem?
-Yes, the gas cap is on..
-No, I do not spill gas on anything..
ac_iconn555 is offline   Reply With Quote
Old 07-15-2005, 01:11 AM   #2 (permalink)
e36surge's Avatar
Does the fumes smell disappear once your tank reaches 3/4?
Your tank may have a leak higher up (highly unlikely as your tank is plastic) or the seal where the sending unit is located may be gone. What year is your car?
Points of interest:
http://www.realoem.com/bmw/showparts.do?mo...314&hg=16&fg=05
http://www.realoem.com/bmw/showparts.do?mo...317&hg=16&fg=15
Number 5, rubber seal.
Here's a write up from Pelican (fuel pump change) telling you where the fuel pump is located. Pull your rear seat and check if you can see any fuel seapage.
http://www.pelicanparts.com/BMW/techarticl...6-Fuel-Pump.htm
Read the article and pay attention to figure 9 and the paragraph that contains figure 9. It mentions the O-ring or the seal I mentioned above.
The e36 has two senders so you'll have to check both seals or O-rings.
Let us know what happens and hope this helps.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 07-15-2005, 07:54 AM   #3 (permalink)
93 325i's Avatar
exactly, replace the rubber seals on the fuel sending units located under the back seat cushion. Also there is a carbon canister that may need to be replaced. This canister apparently gets saturated with fuel and needs replacement.
Complete mod list and pics:
My 1993 325i
Old 07-15-2005, 09:15 PM   #4 (permalink)
Thanks alot guys.. this really helps.. as no one wants to roll around with the interior smelling like gas all day.
-ac_iconn555
Door will not open from inside or outside...HELP!!! tylset 5-Series (E12,E28, E34, E39, E60) 20 03-28-2013 07:23 AM
Slow to start - gas smell irish 3-Series (E21, E30) 2 11-01-2005 02:42 PM
Erratic Gas Guage misterervin 3-Series (E21, E30) 5 09-22-2005 08:20 AM
