Fuse keeps blowing - BMW Forum - BimmerWerkz.com
Old 05-16-2004, 01:19 PM   #1 (permalink)
DaveA is an unknown quantity at this point
On my 316i K reg the fuse for the electic windows and central locking system keeps blowing. have put an avo across the fuse slot and I get a reading that varies between 3 - 10 Volts. Any ideas please.
DaveA is offline   Reply With Quote
Old 05-16-2004, 01:40 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
is there a problem with the Central locking system or windows that you are aware of?
Old 05-16-2004, 01:48 PM   #3 (permalink)
Thanks for the reply Furious but, not that I know of, have just replaced the fuse with one of a higher capacity and although that has not blown the windows or central locking does not work at all now, just have to use the sunroof and hope it does not rain.
Old 05-16-2004, 01:49 PM   #4 (permalink)
kjlbryan is an unknown quantity at this point
Im having the same problem with my 325is... The central locking (CL)fuse (fuse #7) keeps blowing...
I checked the other fuses for the CL system... but all are fine...
One guy I spoke to who works on only BMWS said to disconnect the batteryto reset the system.. Im going to try that this evening...
As requested b4... any ideas anyone?
kjlbryan is offline   Reply With Quote
Old 05-16-2004, 02:04 PM   #5 (permalink)
Thanks Kilbryan, will give it a go because now you come to mention it this all started when I had to replace the battery.
Old 05-16-2004, 02:37 PM   #6 (permalink)
Well I unclipped the battery, left it for 10 mins, replace battery but am still getting 9-10 volts across the fuse slot and still no windows or locking,will have to check the relays under the front facia or get a big hammer and beat the living daylights out of it. Won't solve the problem but will give me on hell of a frustration release.
Old 05-17-2004, 10:36 AM   #7 (permalink)
Super Moderator
dutchbmw's Avatar
You have maybe a short circuit in the electric window system. Be aware of melting wires which have the risk of fire. Never put in higher capacity fuses! Look even for a mechanical problem in the door. When the window is blocking somewhere, it could also be the reason for blowing fuses.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-17-2004, 01:28 PM   #8 (permalink)
Thanks for the advice Dutch but will have to get it into a garage as me and cars don't see eye to eye.
E30 Fuse Box Privateye 3-Series (E21, E30) 5 06-27-2005 09:25 PM
Fuse Keeps On Blowing Off mantra 3-Series (E21, E30) 4 01-07-2005 12:11 AM
Fuse Blade Terminal Clips szidikj 3-Series (E21, E30) 0 08-16-2004 10:59 AM
Shorting in a fuse for guages, and other idling. M5power 5-Series (E12,E28, E34, E39, E60) 0 04-10-2004 11:35 PM
