Fule Door - BMW Forum - BimmerWerkz.com
Old 08-17-2005, 09:48 PM   #1 (permalink)
Car: 2008 128i
Is the fule door lock acutator the same as the door lock actuators. If so the front or the rear actutor for the door as I found 2 at bav auto...
2008 128i Jetblack
Old 08-18-2005, 11:26 PM   #2 (permalink)
SD318is is an unknown quantity at this point
btt, i would like to know also. my fuel door is always flappin around
SD318is is offline   Reply With Quote
Old 08-19-2005, 08:15 AM   #3 (permalink)
RallyE36 is an unknown quantity at this point
The fuel door lock is actuated with the general door locks.
The actuator could be malfuctioning. You can ckeck this out by leaving the fuel door wide open then go to the passenger door and lock/unlock it with your key. You should be able to see the metal stem in the fuel door go in and out as you lock and unlock the passenger door. If this isn't happening then the actuator is not working. Check wiring connections to it from inside the trunk.
Good luck.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 08-20-2005, 12:34 PM   #4 (permalink)
Car: 2008 128i
Good luck.
[snapback]370844[/snapback]
The metal stem is not going in and out that is how I know its not locking.
I want to know what actuator it is to replace it. The wiring connection is solid I have yet to check the voltage when locking/unlocking.
2008 128i Jetblack
Old 08-20-2005, 02:17 PM   #5 (permalink)
quality
Delmarco's Avatar
your fuel door locks?
i never knew that was a feature of our cars...
mine's doesnt.
Old 08-20-2005, 07:07 PM   #6 (permalink)
WarNox's Avatar
if it didnt then any1 could come nd steal your fuel cap nd put crap in ur fuel tank!
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 08-20-2005, 07:22 PM   #7 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
i have read that they lock on our cars, but the cap on my 325is doesn't lock. even when i double lock the doors! it just twists right off, why is this?
kyle_baker is offline   Reply With Quote
Old 08-21-2005, 09:10 AM   #8 (permalink)
quality
Delmarco's Avatar
hold on the door doesnt lock...but the cap does?!!!!
WTF!!!
I never knew that...I got to run down to my car right now and check that out....
Old 08-21-2005, 10:54 AM   #9 (permalink)
kyle_baker's Avatar
lol, i'm not sure either, neither the door nor the cap locks on my car. i don't see how the door could lock tho, it just flips open and closed with no latch. i thought the cap would be what gets locked down, anyone?
Old 08-21-2005, 11:43 AM   #10 (permalink)
I don't understand how you guys can get so confused.
Since the beginning of this topic we've been talking about the fuel door. That's the metal door you see from the outside which flips open sidesways, and not the roud black fuel cap that you rotate by hand. Geeeesh !!!
The fuel door locks .... yes, locks when you normally lock all your doors. The fuel cap doesn't lock, unless some of your cars have a locking cap which somebody purchased at an autostore. The BMW standard cap doesn't lock. The security relies on the locking door.
The locking door has an small actuator which controls the little black metal stem you should see going in and out when you lock your doors. This actuator is located just behind the stem and should be accessed from inside the trunk. You will have to remove the trunk lining.
Now, I hope this will clear things up.
Canadian Model
Old 08-21-2005, 11:52 AM   #11 (permalink)
quality
Delmarco's Avatar
WTF....dude...there is no way that door locks. Its just a flap on a spring hinge...there is no actuator or anything else there. ...
on the E39 cars and E46 cars the flap locks but never seen that on a E36 car.
you gotta post a picture of that...maybe the previous owner modded your feul door to lock.
Old 08-21-2005, 02:27 PM   #12 (permalink)
kyle_baker's Avatar
[snapback]371326[/snapback]
lmaoarifc, i am 100% with Delmarco. i have never seen this little black metal stem that locks the fuel door. lol, maybe they didn't amke the 1995 318 and 325 models with locking fuel doors, lol. seriously tho, take a picture, that would help more than anything else right now. me and Delmarco are on the same level and we're both stumped.
Old 08-21-2005, 07:58 PM   #13 (permalink)
crunkjuice's Avatar
crunkjuice is an unknown quantity at this point
I had the the same problem, honestly dont replace anything until u grease or oil up the door. when my car was gettin tuned my i thought i had to replace something but all my mechanic said he had to do was lube it up. now it works fine
crunkjuice is offline   Reply With Quote
Old 08-21-2005, 08:38 PM   #14 (permalink)
kyle_baker's Avatar
i'm confused, what are you suggesting is the problem?
Old 08-21-2005, 09:19 PM   #15 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
As far as I know, all E36's with central locking have it . . .
Dudesky_E36 is offline   Reply With Quote
E36 Door Panels Switched!!!! Delmarco 3-Series (E36) 3 06-10-2005 09:12 AM
Door Situation hnhan 3-Series (E46, E90) 2 04-08-2005 04:33 PM
Solution to Door Edge Seal Problem zulkhernain 5-Series (E12,E28, E34, E39, E60) 4 09-16-2004 09:24 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
