Fuel Pump Relay Location On 325i - BMW Forum - BimmerWerkz.com
Old 01-15-2005, 06:22 PM   #1 (permalink)
Brian3251 is an unknown quantity at this point
Iam still trying to start my 95 325i.Iam just about reay to take it to the shop,but before i do that i want to put a new fuel pump relay in.Been looking forever for this where is it.Is it in the fuse box under the hood.I think its a 30 amp and does anyone know if it could be the reason my car wont start,it tries to and when it does it runs for about 3 seconds and dies out.The plugs are wet and it getting spark.It ran great before this problem.
Brian3251 is offline   Reply With Quote
Old 01-15-2005, 06:25 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yes.. its in your front forward distribution box.. located in the lower left part of the engine bay.. as if you were sitting in the drivers seat. If I'm not mistaken.. it says fuel pump on it... I'm not on my home computer.. I have a picture displaying every single relay in there.. but I'm not at home.. sorry..
I know someone on here has a picture of that diagram...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 01-15-2005, 07:03 PM   #3 (permalink)
Good Luck,
Les
[snapback]272222[/snapback]
Your not talking about the fuel pump fuse are you i know where that is,but the realy is what i need to find it has the 4 prongs on it and its like a 1x1 inch square plastic box.I know just about evveryone on here probaly knows where it is but me.This my first BMW.
Old 01-15-2005, 11:26 PM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yes.. same location that I stated... hold and I'll get someone in here to help you...
Les
Old 01-15-2005, 11:40 PM   #5 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
hope this helps
sorry for crappy camera, if u can't read it i can type it out for u
2011 Mazda2
1990 Mazda Miata
Old 01-15-2005, 11:42 PM   #6 (permalink)
Science Roolz!
well looks like i over did it, but hey this will help others too hopefully so it's all good
2011 Mazda2
1990 Mazda Miata
Old 01-16-2005, 09:21 AM   #7 (permalink)
Super Moderator
dutchbmw's Avatar
http://www.pelicanparts.com/bmw/techarticl...6-Fuel-Pump.htm
I didn't read the article, perhaps you can use it.....
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 01-16-2005, 01:32 PM   #8 (permalink)
[snapback]272528[/snapback]
thanks for the artical/info it seems pretty basic.I have done a few,at least its on top and not at the bottom of the tank. should i hear this pump run when i turn on the ignition ? some yes and some say maybe not ? I guess i should just check for voltage first.
Old 01-16-2005, 03:10 PM   #9 (permalink)
Originally posted by Brian3251+Jan 16 2005, 03:32 PM--><div class='quotetop'>QUOTE(Brian3251 @ Jan 16 2005, 03:32 PM)</div><div class='quotemain'><!--QuoteBegin-dutchbmw@Jan 16 2005, 11:21 AM
[snapback]272643[/snapback]
[/b][/quote]
There are 2 wire connectors on the pump i have 12 volts from the one ,looks like i need a fuel pump because i hear no sound from it.
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump Relay 1997 328ic Convertible, Electrical eclipsevrl 3-Series (E36) 1 06-05-2005 11:11 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
Fuel Pump Location Biernacki 3-Series (E46, E90) 2 02-16-2005 01:57 PM
