Fuel Pump Or Relay? - BMW Forum - BimmerWerkz.com
Old 03-05-2005, 02:29 PM   #1 (permalink)
sicnick325i is an unknown quantity at this point
Thumbs up
My car will not start. It is definitly not getting gas to the engine and the fule pump is not making any noise. How do i tell if the problem is in the pump or in the relay?
I just changed the o2 sensor.. could that have anything to do with it?
the ignition was left on until the battery went dead (stupid i know, but it happend )
Nick 92 325i M50
'92 e36 325i M50
sicnick325i is offline   Reply With Quote
Old 03-05-2005, 02:37 PM   #2 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
get a fuel pump pressure tester... that will show you if you have pressure or not even if your relay went bad.
jrhaile is offline   Reply With Quote
Old 03-05-2005, 03:19 PM   #3 (permalink)
If you do not hear the fuel pump buzzing I would suspect that, however you could disconnect fuel line at the filter, put line in a container and have someone turn on ignition and see if she pushes any fuel. Be careful and quick if you do this.
Old 03-05-2005, 03:45 PM   #4 (permalink)
Gator is an unknown quantity at this point
With a voltmeter test to see if you have 12 volts at the fuel pump. If yes your fuel pump is bad, if no your relay is bad.
Gator is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump Relay 1997 328ic Convertible, Electrical eclipsevrl 3-Series (E36) 1 06-05-2005 11:11 PM
Fuel Pump Relay 96 740 p_villa3030 1,6,7,8 - Series and Mini Cooper 1 04-10-2005 06:23 PM
Where's the fuel pump relay? meh001 3-Series (E21, E30) 2 08-08-2004 05:53 PM
