fuel pump - BMW Forum - BimmerWerkz.com
Old 06-09-2004, 01:12 PM   #1 (permalink)
tico481's Avatar
tico481 is an unknown quantity at this point
Send a message via AIM to tico481 Send a message via MSN to tico481
What do I need to look for when my fuel pump is going bad? I think mines going bad because sometimes when i floor it, the car hesitates, and abbout a a second later it speeds up fast. Does anyone know if that might be the fuel pump?
<u>1995 BMW 325is</u>
- //M3 Spoiler
- 15% Tinted Windows
- Front License Plate Delete
If I say something stupid, it's probably cause I'm ripped
tico481 is offline   Reply With Quote
Old 06-09-2004, 05:11 PM   #2 (permalink)
Super Moderator
dutchbmw's Avatar
It could be.... A way to check is to remove the return fuel line (after the pressure control at the fuel rail) and see if gas flows through the pressure unit. When gas flows back to the tank, the fuel pump isn't going bad. Be careful when doing this check because of the high flammable or explosive gas. Good luck!
Pieter
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 06-09-2004, 06:24 PM   #3 (permalink)
tico481's Avatar
I think it's either the fuel pump, or the injectors. Hopefull nothing big
- //M3 Spoiler
Old 06-12-2004, 08:00 PM   #4 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
i just had to replace mine, car ran great forever then it didnt want to start two times (i eventually got it going) then one day it crapped out on me. so if this happens to you, may want to check into it
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Old 06-12-2004, 08:10 PM   #5 (permalink)
Speedy-325is's Avatar
BMW fuel filters are designed @ euro gas specs(much cleaner than us) & if u r not using at least 91octane (US), u will probably go through them pretty quickly. this will also lead to premature destruction of your fuel pump.
if u havent changed if in a while (40,000miles) u might want to do it regardless.
be sure to buy good filters too! dont go to pepboys. turnermotorsports.com has them for a few bucks each made by MAHER, good stuff.
Old 06-12-2004, 08:59 PM   #6 (permalink)
thekid's Avatar
There is so many other things it could be other than your fuel pump. Does you car have a hard time starting? If it does than I would check out the pump/filter. If not I would look else where for the problem.
Old 06-14-2004, 11:41 PM   #7 (permalink)
killerjz is an unknown quantity at this point
Send a message via AIM to killerjz Send a message via MSN to killerjz
to me it sounds like the plugs or the worst it could be the ignition coils. check ur plugs .
killerjz is offline   Reply With Quote
Old 06-15-2004, 01:58 AM   #8 (permalink)
FireBlue323IS is an unknown quantity at this point
Just a suggestion. You might want to start with replacing your spark-plugs. To me that sounds like a spark-plug problem. Basic rule of thumb is if you are getting backfire from your engine (Intake) it is being fuel starved (lack of fuel maybe...fuel pump?). I would start with plugs because they can get hairline cracks that can arc within or just be bad this will cause hesitations at all speeds but more noticable at lower speeds during acceleration. I would start there or your likely to chase your tail. Plus it is cheaper! Let me know if it helps.
FireBlue323IS is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump BMW for life 5-Series (E12,E28, E34, E39, E60) 2 02-25-2005 05:03 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
