Fuel Pressure Regulator - BMW Forum - BimmerWerkz.com
Old 12-13-2004, 07:47 PM   #1 (permalink)
bluee36e36 is an unknown quantity at this point
how and where do you hook up a fuel pressure regulator, on a 93 325is?
bluee36e36 is offline   Reply With Quote
Old 12-14-2004, 05:56 PM   #2 (permalink)
anyone?
Old 12-14-2004, 06:51 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
Are you merely needing to replace a faulty unit?
I've always read that it is located on the back side of the fuel rail in the engine bay, but I recently replaced mine with an adjustable unit and it was underneath the car (about where your gas pedal is)behind a silverish metal shield that protects it
Old 12-16-2004, 02:29 PM   #4 (permalink)
i'm putting on an adjustable unit also, how would you go about doing it?
Old 12-16-2004, 06:12 PM   #5 (permalink)
WOT in Reverse
jllphan's Avatar
I did that last week.
Which one did you get, the one from bavauto?
And why are you adding an adjustable unit, the only reason I did, was because I have an OBDII engine mated to an OBDI induction system and was starving my engine. If you've not done an engine swap (or something of the like), I can't think of a good reason to add such used
Old 12-16-2004, 09:41 PM   #6 (permalink)
the reason i'm putting an adjustable unit on my car is that i have a straight exhaust and a cold air intake, along with headers. i heard that since i have more air coming in and going out, i need more fuel to keep the air/fuel ratio the same as stock. i also have a dinan chip. so how did you do it?
i asked my local speed show, westminster speed and sound, and they said that it would add about 5-8 horses and make the throtle response better.
Bmp Afpr (adjustable Fuel Pressure Regulator) h4rdwire Aftermarket Parts 4 05-19-2005 04:11 PM
Need Fuel Pressure Regulator - What's Best On-line pcy 3-Series (E36) 0 04-20-2005 10:34 AM
Replacing Fuel Pressure Regulator shield 3-Series (E21, E30) 3 03-07-2005 11:55 PM
Replacing Fuel Pressure Regulator adavis 3-Series (E21, E30) 0 12-14-2004 02:25 PM
How to test fuel system pressure? babzenuda 3-Series (E21, E30) 4 01-13-2004 04:35 AM
