Fuel/Petrol Overflow - BMW Forum - BimmerWerkz.com
Old 05-27-2009, 04:41 PM   #1 (permalink)
defcomk is on a distinguished road
So My dad recently changed the cylinder head and had the block repaired we put everything back together the car started, now my dad took it on a test run he was at a gas station refueling. Now when he tried starting it it did not want to pick up he also noticed a gasolin smell in the car theres petrol overflowing in the head more coming in than it can burn. it also has a unstable idle its like someone is reving it and cutting out reving it and cutting out. i drove it and noticed it has a slow pull up a hill but moves like a bullet on the straits but the pullaway relativly slow so does any one know what the problem could be also the cable above the crank sensor was removed it did not look like it had a use thanks
defcomk is offline   Reply With Quote
Old 05-27-2009, 05:42 PM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Oh wow. This is beyond what I know how to fix, but I hope you guys can sort it out. Good luck.
Turkey Fleet Bond Holder
Old 05-27-2009, 07:11 PM   #3 (permalink)
Could it be an over active fuel pump?
Old 05-27-2009, 08:31 PM   #4 (permalink)
it could be i should mention its been out of action since last year june also the rubber pipes which connect to the injectors were replaced the water pump and oil pump were changed there a leak in large pipe that connect from air filter box( what ever its called).everything is stock standard except for the exhaust system. il give some history about it the car started overheating last year ended up burnin da gasket which lead to a cracked cylinder head, which then lead to the cylinder head going missing then turning up again after we had already gotten another cylinder head. when putting it back the timming was all wrong kept bending valves but thanks to this i found pictures of the right timming anyway the battery ran out we decided to kickstart it worked but then turned of we tried again this time i was kick starting, situation went from bad to worsterrible only word to describe . anyway as i was kick starting it it made like it was about to pickup i head a knock more like a thud from the bottom of the car. the piston had gone loose or something smacked into the block chipped nd made a tiny hole, my dad took the block to the engineer had it welded and mended into place we put the block back now we back to the overflowing gas . many mechanics have come and fixed this car this is the bmw from hell problems after problem my dad dont want to give it up aargh anyway yeah thats all folks
pwned by sewer overflow Ivan Video Vault 6 04-21-2007 09:41 PM
Petrol for an '83 528i AngelMoo 5-Series (E12,E28, E34, E39, E60) 7 01-09-2006 10:23 PM
Petrol Overconsumption zlac109 3-Series (E36) 3 10-18-2004 06:56 PM
petrol/gas Rich328 3-Series (E36) 13 06-27-2004 11:26 AM
Fuel Tank Overflow Kevin325i 3-Series (E36) 4 06-09-2004 07:14 PM
