Fuel Meter / Gauge On E36 - BMW Forum - BimmerWerkz.com
Old 08-01-2005, 09:01 AM   #1 (permalink)
oe_tuning is an unknown quantity at this point
hi guys....
i got a question on my fuel gauge:
this thing is moving up and down constantly, like one minute its 3/4 and then ten minutes later its less than 3/4 and then it goes higher than 3/4
what can be wrong about this?
is there an easy (and cheap) fix for it?
thx!!!
oe_tuning is offline   Reply With Quote
Old 08-01-2005, 10:37 AM   #2 (permalink)
e36surge's Avatar
Common problem.
Incorrect Fuel Gauge Reading
Model:
BMW E36 (3 series) including BMW 318ti produced from January 1995
Complaint:
Due to the formation of a non-conducting deposit on the conductor surface of the fuel level sensor, the fuel gauge does not read full after re-fuelling, or the fuel gauge is erratic. Remedy:
Remove and replace both fuel level sensors with “Gold system” sensors.
Fuel Gauge Stays Empty after Refuelling/Fuel Gauge Erratic
Model:
BMW Z3 Roadster/coupe, BMW M roadster/coupe (E36/7). Vehicles produced before December 15 2000
Complaint:
After refuelling the fuel gauge will stay on empty or the fuel gauge is erratic. This is caused by a non-conducting deposit being formed on the conductor surface of the fuel level sensor. For the Z3 from September 1998 and the M roadster/coupe FC 2 (Fuel sensor voltage plausibility) will be set in the Instrument Cluster.
Remedy:
Remove and replace the fuel level sensor with a ‘Gold system’ sensor referring to repair instructions 16 12 000.
Look thru these links.
http://member.rivernet.com.au/btaylor/BMWT...mpGaugeE30.html
http://member.rivernet.com.au/btaylor/BMWT...erDescript.html
http://www.usedcarmart.co.uk/forum/archive...php/t-4187.html
http://home.att.net/~ebaines/digest....0gauge%20error
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
Fuel Gauge Probs Man314 5-Series (E12,E28, E34, E39, E60) 1 03-08-2005 09:20 PM
Recall On Fuel Gauge MaThGr82 3-Series (E46, E90) 1 10-17-2004 12:29 AM
E36 320 FAULTY FUEL GAUGE Markyb87 3-Series (E36) 5 05-24-2004 09:52 AM
Fuel Gauge Problem BeemerMan 3-Series (E36) 1 09-18-2003 07:22 PM
