Fuel Issue. - BMW Forum - BimmerWerkz.com
Old 09-30-2005, 06:56 PM   #1 (permalink)
Cloxe is an unknown quantity at this point
Fuel Issue.
Okay so i've got a 1994 318i i was driving home from work and made a stop. At the stop the car idled shortly then kinda chugged and then died.
What my question is to you guys is whats a fuel pump usually run price wise and also i've heard that my car has two fuel pumps one inline and one in tank so basically just looking for a few answers. Also all fuses were check, placed more gas in take incase the gague was wrong. whats your ideas.?
Cloxe is offline   Reply With Quote
Old 09-30-2005, 08:22 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
before you get going on this , how did you diagnose its the fuel pump?
Old 09-30-2005, 09:18 PM   #3 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
Clean Your Idle Control Valve, it could be that and also check your ignition components.
and check all other DUh! no wonder items like your battery being properly tied down and both cables being bolted down.
BImmerN2B is offline   Reply With Quote
Old 10-01-2005, 01:37 AM   #4 (permalink)
well my first guess that the gague read wrong. So i bought some gas .
when i would try to start it it would start and idle for about 2 seconds and then putt out. Also typically you can hear your fuel pump make the wine noice when the key is turned but not fully i no longer heard that sound. I checked the fuses,checked the around all my tubing to make sure the correct air was being taken in because once before my car wouldn't start due to the fact it was taking it the wrong air..
So i just took a guess and figured it was the fuel pump. i mean even if it's not it's about time to change the pump and filter anyway it's got a 193.xxx miles.
Old 10-01-2005, 09:02 AM   #5 (permalink)
BImmerN2B's Avatar
Here is another Guess. If you have taken your car trough a car wash or washed it with a high pressure hose, then it may have flooded your DME which is your car computer. When that gets flooded or wet, your car would tend to do that and leave you clueless as to what is the problem.
The compartment to the computer could even hold up to a gallon of water and this wasn't fixed until about 96-97 by bmw. Try to see if that could be the problem
Old 10-01-2005, 12:47 PM   #6 (permalink)
Fuel pump fuse gets hot ?
Do you notice if the fuel pump fuse gets hot to the touch when this happens? That's a good indication of a failing fuel pump. How old is the fuel filter? Could it be clogged?
Mike
Fuel pump fuse....
Hamfisted is offline   Reply With Quote
Old 10-01-2005, 02:28 PM   #7 (permalink)
sadly i haven't washed the car in some time we had a decent rain but i highly doubt after the amount of rain we've had in the past that this time would be any diffrent.
The fuel filter hasn't been changed since i owned the car so it's hard to say when the last person did it .. maybe a good idea to check it out
Old 10-02-2005, 02:46 AM   #8 (permalink)
what my real question in all this was to figure out if there was two fuel pumps in my car.
I got a quote and the guy said my car had two fuel pumps one in line and one in tank.. but maybe he was thinking about the fuel filter.
Old 10-02-2005, 11:44 AM   #9 (permalink)
Just an in-tank pump....
Your 318 just has an in tank pump. P/N 16 14 1 182 842 , about $150.00. If you've never changed the fuel filter try that first, you'll need to anyway.
Mike
Old 10-02-2005, 03:06 PM   #10 (permalink)
alright thanks guys for helping me out with all my questions.. new fuel pump is coming shortly and i think i got it for about 130 dollors so with labor and all maybe around 200.. thanks for the help.
Old 10-02-2005, 03:12 PM   #11 (permalink)
ex owner/admin
Furious's Avatar
pending that change, if you still seem to get the problem id check out that fuel filter, they can really cause issues.
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Grumble Grumble Fuel Guage Issue Smash 3-Series (E36) 1 05-07-2005 04:07 AM
whisling sound at fuel filter javieruz 3-Series (E21, E30) 2 04-12-2004 10:17 PM
