Fuel gauge showing empty - BMW Forum - BimmerWerkz.com
Old 04-28-2006, 03:23 AM   #1 (permalink)
mathijskok is an unknown quantity at this point
E36 320i Convertible, 1996 build
Last night I filled the tank only to find the gauge showing full empty with the warning light burning. I checked out the Haynes but I can't really find where to start looking. Anybody any suggestions?
Mathijs
mathijskok is offline   Reply With Quote
Old 04-28-2006, 01:40 PM   #2 (permalink)
Check fuel quantity senders...
Lift out the rear seat and check the terminals on the fuel quantity senders. They get corrosion on 'em and kill the signal to the gauge. If you have a multimeter check that there is resistance between the pins on the sender itself, not zero or infinite resistance, but 100-300 ohm resistance.
Mike
Hamfisted is offline   Reply With Quote
Old 04-28-2006, 02:12 PM   #3 (permalink)
Mike
Okodoki, will do that tomorrow. I know my electrics so I should be able to get that. I found the sensors, but not yet how to detect if they were faulty. I did clean them though, no results. But with your help I should at least be able to detect WHERE the problem is, great support, thanks!
Funny, I found a whole bunch of little seedpods in the left one, obviously some mice used it for a while. It's a great little hiding place for them. Means I will have to check the wires better of course. Those guys eat wires.
Old 04-28-2006, 03:09 PM   #4 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
MMMMM MICE MUNCHIES!
Old 04-29-2006, 06:21 AM   #5 (permalink)
Mike
221 ohm on one, infinite on the other (the one with the fuel pump). Sounds like a clear case of replacement or is there anything to check when I take out the sensor? And when I do take that bit apart, makes it any sense to replace the fuel pump as well? Car done 120.000 kilometers (say 75.000 miles).
Old 04-29-2006, 10:59 AM   #6 (permalink)
That's not a lot of miles for the sensor to already go bad . But that side comes as a complete replacement set (pump and all...) and it's the more expensive side obviously ($160-$175). I thought you might get lucky and it would just be dirty terminals.
Right side fuel quantity sender and fuel pump unit ..... one piece.
The left side quantity sender has no fuel pump attached....
Mike
Old 04-30-2006, 04:39 AM   #7 (permalink)
Well, I'll order the bit and replace the whole thing, seems simple enough. Thanks for the superb help Mike! Certainly saved me a hell of a lot of money!
Fuel Gauge Wire Bear 3-Series (E21, E30) 0 03-16-2006 02:03 PM
Fuel Gauge Probs Man314 5-Series (E12,E28, E34, E39, E60) 1 03-08-2005 09:20 PM
Fuel Gauge JY9024 3-Series (E36) 8 11-29-2004 11:18 PM
Recall On Fuel Gauge MaThGr82 3-Series (E46, E90) 1 10-17-2004 12:29 AM
