Fuel Filter - BMW Forum - BimmerWerkz.com
Old 03-20-2005, 01:28 PM   #1 (permalink)
Steinkek is an unknown quantity at this point
Has anyone in here ever replaced their fuel filter? how easy is it? and where is it located?
thanks kris
Steinkek is offline   Reply With Quote
Old 03-20-2005, 01:31 PM   #2 (permalink)
jshearer's Avatar
Car: 1994 325is
jshearer is an unknown quantity at this point
I have not replaced it, because when I talked to people they said it would normally be an easy job but that the BMW one is not easy to get to and it can be real messy.
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/3466/quicksignature20te.jpg" border="0" width="600" alt="Image Hosted by ImageShack.us" /></a>
jshearer is offline   Reply With Quote
Old 03-20-2005, 07:37 PM   #3 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
On the earlier models its kinda hard because you have little room to work. Its by the driver engine mount. But its actually kinda simple. There is a large clamp that goes around the filter and there is a rubber insert. Losen the nut enough so you can spin the filter. Clamp the hose on top of filter and same with the bottom. There is a clip that holds the top hose on thats semi hard to get to. You need a preaty small screwdriver. The one in ur trunk is too big. Just pray the last person put it on right, so that the little part you have to turn is facin the right way. After you take off the top hose a little gas will come out, but you can wipe it off. Make sure you clamp close to the filter opening so less gas comes out. You will however have fuel in the filter, so use the rubber nipple from the new one and put it on the open part of the filter. Disconnect the bottom and make sure the filter is upside down so that no fuel will come out from the open end you just disconnected. Once again a little fuel will come out of the hose. Install the new one doing all the steps in reverse and your set. But you have a later model and I think your filter is actually under the driver and its a lot easier to replace. Its all in plain view. Clamp hoses, have a rag ready, and thats about it. Make sure the filter is on right. The flow arow points towards the engine.
-Serge
theruss1an1 is offline   Reply With Quote
Old 03-20-2005, 07:40 PM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
i bought the fuel filter, just havn't had time to put it in.. me and my buddy are gunna do it this week!
-SOLD..
R.I.P Fast 6
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
Fuel Filter Issues dsstultz 3-Series (E21, E30) 6 04-12-2005 11:07 AM
Changing The Fuel Filter hocuzanden 3-Series (E36) 13 12-11-2004 08:45 PM
whisling sound at fuel filter javieruz 3-Series (E21, E30) 2 04-12-2004 10:17 PM
