Fuel Delivery Issue? - BMW Forum - BimmerWerkz.com
Old 01-26-2006, 09:40 PM   #1 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
Question Fuel Delivery Issue?
I believe that I have a fuel delivery issue. More specifically, I think my fuel filter/pump or a conecting hose has a leak. Without knowing the anatomy of my car specifically, just aft of my driver side firewall I have a mild leak. The last time I was under the car, I do recall seeing a cylinder shaped object. I haven't looked closely, but I am assuming it's either the fuel filter/pump or one of the conecting hoses. Anyway, it causes an odd idle as if the car (92 318is) was running on 3.5 cylinders. Hopefully that is all it is. I'd hate for it to be an injector or worse.
Any input is appreciated. Thnx.
dvmotorsports is offline   Reply With Quote
Old 01-26-2006, 10:46 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Can you take a picture of what you think is leaking and post it here?
DT
DT
Old 01-27-2006, 02:02 AM   #3 (permalink)
I am computer illiterate (took 4 times to spell computer too). So, no on the photo as of right now.
Anyway, I also should have added I know for sure there is a leak. I just don't know if it is the culprit. But from my knowledge, I am pretty damn sure that is the problem.
Old 01-27-2006, 01:32 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Well the fuel filter should be on the left side underbody and have a thin metal cover shielding it. If you remove the cover you can access the fuel filter and see if 1 of the hoses is leaking, or more commonly a hose clamp is either broken or loose.
Good Luck
DT
DT
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Fuel Issue. Cloxe 3-Series (E36) 10 10-02-2005 03:12 PM
Grumble Grumble Fuel Guage Issue Smash 3-Series (E36) 1 05-07-2005 04:07 AM
fuel delivery system questions SeatTime 3-Series (E46, E90) 1 10-08-2003 08:29 AM
