Fuel Cleaner/ Injector Cleaner - BMW Forum - BimmerWerkz.com
Old 01-29-2005, 03:23 AM   #1 (permalink)
socalguy is an unknown quantity at this point
just need some on advice on what fuel / injector cleaner you all use for your bmws. it will be going in a 1996 328is. 78k.
socalguy is offline   Reply With Quote
Old 01-29-2005, 11:06 AM   #2 (permalink)
Rooz's Avatar
Car: 2003 M5
It really doesn't matter, try using one with octane booster.
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 01-29-2005, 11:10 AM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I've always used either Lucas... or some Chevron Techron works great...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 01-29-2005, 11:28 AM   #4 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
yeah lucas is one of the best IMO
abemcclellan is offline   Reply With Quote
Old 01-30-2005, 02:44 AM   #5 (permalink)
col thanks eeryone
Old 01-30-2005, 03:05 AM   #6 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
i dont mean to hijack, but this is related. My car gets shitty gas mileage. I put a thing of injector cleaner in it, and the tank still ran quickly, the next tank seemed to last for an ok amount of time, put another bottle in and now its running out fast again. Does the tank run out fast with the cleaner in it or what?
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Old 01-30-2005, 09:25 AM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
No it shouldnt... you also have to remember... the amount of fuel you burn is also related to outside air temperature... the amount of throttle you use.. the condition of your O2 sensors... fuel injectors.. ect... if your getting horrible gas mileage... natural troubleshooting says get a tune up... spark plugs.. injectors... filters.. oil.. fluids... sensors... ect.. fuel injector cleaner.. does just that... cleans the filters...
Actually it sounds as if you are adding the injector cleaner when your fuel tank is full... if you follow the directions.. and add it towards the end of your fuel tank.. (almost empty)... it will mix better and burn the clunck out of your injectors... if you use it in a full tank.. it isnt as concentrate...
Good Luck,
Les
Old 01-30-2005, 10:32 AM   #8 (permalink)
Rooz's Avatar
Car: 2003 M5
[snapback]282283[/snapback]
Try using called "Guaranted to pass" it's like a fuel injector cleaner but a bit more powerful, and cleans a few more things, that helped me.
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Fuel Injector Cleaner Clint_M 3-Series (E36) 10 02-21-2005 03:06 PM
Fuel Injector Cleaner okczy21 3-Series (E36) 17 10-17-2004 06:00 PM
Fuel system cleaner recommendations first5ny Picture Showroom 3 05-22-2004 04:45 PM
