Front shock absorbers guide support problem - BMW Forum - BimmerWerkz.com
Old 07-13-2009, 04:10 PM   #1 (permalink)
nos
nos's Avatar
Car: E36 325i 24v Coupe
nos is on a distinguished road
Send a message via Yahoo to nos
Unhappy Front shock absorbers guide support problem
Hey guys, i have changed yesterday both front guide supports, and i have a strange problem...my car front is higher with almost 3 centimeters than before. I have ordered the parts from the bmw representative, original parts, and i don't understand this situation. The new guide supports are a little bit different than the old ones, but they have fitted perfectly into my car, but she's staying more higher than before. Can it be wrong parts, i mean, if these guided supports are from the e39 or e81 models could they fit on my car's body and also with the suspension? Or maybe there are more than one type of supports for the e36 model? I have a e36 325i coupe (not m3 technic) build 07/1992.
Thanks guys.
Mike
nos is offline   Reply With Quote
Old 07-13-2009, 08:12 PM   #2 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
can you post a picture of what a guide support is. I'm not sure what you mean. If you're referring to springs? Then the old ones were probably old and tired and caused the front to sag.
2011 Mazda2
1990 Mazda Miata
Old 07-13-2009, 08:35 PM   #3 (permalink)
bmwinsider's Avatar
Car: 97 m3 "family sedan" & 87 325is
bmwinsider is on a distinguished road
IF you just put them on drive around within 3 -5 miles it should come down to normal height. That is if there is any stress on the new parts ( it will seat itself) yes there are different parts for this app.
Do you REALLY think we need security codes for stock radios , HOW ABOUT AN IGNITION CODE!
bmwinsider is offline   Reply With Quote
Old 07-14-2009, 03:13 PM   #4 (permalink)
nos
nos's Avatar
Hey guys. The correct name for that part (i assume ) is STRUT MOUNT, i didn't knew it in English, sorry...I made some research today and yes, you were wright sahab, the old ones were there from 1992 when the car was born! And of course, they were very tired, and lowered the front with approx 2 cm! But they didn't have absolute any gap until one week ago when i ran into a big pothole...
So the old model is not in production anymore (picture 1) and it was replaced with the new aluminium model (picture 2), using the same technology as for the newer bmw models.
The problem is now that my car is staying higher in the front than in the back, and for that i have ordered also the back strut mounts, and i will change it on thursday, of course, i'll come back to you with news.
Mike
Old 07-14-2009, 04:40 PM   #5 (permalink)
Science Roolz!
sounds good, hope that works out for you.
2011 Mazda2
1990 Mazda Miata
Old 07-26-2009, 02:02 PM   #6 (permalink)
nos
nos's Avatar
Hey guys, i managed to change the rear strut mounts, but it didn't solve the height of the car. I have made some more research and found out that those strut mounts can deform in time, especially if you have stiff sport suspension. So i re-tuned the front and rear suspension, in order to be as the bmw tech specs for the sport suspensions. Here are the dimensions, measured from the center of wheel arch to bottom of wheel rim ( for 17" wheels and sport suspension).
Front - 560 mm (22.05 inches)
Rear - 535 mm (21.06 inches)
Thanks for your support.
Mike
Old 07-27-2009, 10:44 PM   #7 (permalink)
Car: 95 318IS,CTS-V, 97 328IS, 97 M3
qualicas is on a distinguished road
Make sure your springs are properly seated. If they are turned slightly they would not fit the top and bottoms properly causing the car to sit higher.
qualicas is offline   Reply With Quote
4 Questions – e39 – 530i – 2002 (shock absorbers) rashid 5-Series (E12,E28, E34, E39, E60) 7 03-16-2009 01:52 PM
Rear Shock Absorbers Rookie 3-Series (E36) 0 08-17-2005 09:25 AM
328is Mtec Shock Absorbers dangreen 3-Series (E36) 2 03-14-2005 10:03 AM
Front Cross Radiator support (bolted or welded?) broken_down_bimmer 3-Series (E36) 1 07-26-2004 04:43 PM
