Front Brakes - BMW Forum - BimmerWerkz.com
Old 01-03-2005, 02:18 PM   #1 (permalink)
93 325i's Avatar
I ordered the parts to do my front brakes-OEM rotors & Hawk HPS Street pads. Now when I go to do this job do I have to bleed the brakes? Should I do a brake fluid bleed anyways? If it is suggested that I bleed them do I have to bleed the rear brakes too? or can you just bleed the fronts?
Complete mod list and pics:
My 1993 325i
Old 01-03-2005, 03:07 PM   #2 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
You won't HAVE to bleed them if you use the C-Clamp method to compress the cylinders because the fluid system won't have changed. If your braking still seems rather off when you are done, you may need to go back to bleed the system. If you do want to, bleed all the lines because its possible air could be introduced temporarily, making your brakes catch late and your brake pedal very soft.
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 01-03-2005, 03:38 PM   #3 (permalink)
Threadkiller
bitcore's Avatar
Weird, hopefully I'm doing the exact same thing tomorrow at my dad's race shop... Hawk HPS and OEM front rotors.... (well not HIS race shop, but he goes there with his stockcar)
Old 01-03-2005, 04:04 PM   #4 (permalink)
93 325i's Avatar
Yea I plan to do the C-Clamp method on the caliper piston.. Thanks for the info..all in all I got the parts shipped to my door for $160. BMW wanted $400-HA screw them..i'll save myself $250
My 1993 325i
Old 01-03-2005, 04:08 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
400$ for what? pads & rotors?
they charged me only 65$ for each rotor...
Old 01-03-2005, 05:27 PM   #6 (permalink)
bimmer_boy's Avatar
bimmer_boy is an unknown quantity at this point
Send a message via AIM to bimmer_boy
I just did mine two days ago using the c-clamp method. Worked perfectly and brake are fine. Just be sure to change the sensor. You can get one for a mere 15 bucks from BMW. That's relatively cheap considering the source.
BLACK 1995 BMW E36 325i
• <u>Dinan</u> Performance Software - SOLD!
• High-flow intake w/ Green Performance Filter
• 17 x 8.5 BMW Style 44 Rims
• <u>Pirelli</u> P6 tires 235/45/17
• M3 Spoiler
• Clear Tail Lights, Corners, and Side markers
• 20% Tint all around
• Sylvania Silverstar Bulbs
• <u>Alpine</u> 9831 MP3/CD Player
bimmer_boy is offline   Reply With Quote
Old 01-03-2005, 07:43 PM   #7 (permalink)
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
Hey guys, please let me know how this works out for you.
I want to get Hawk pads as well but I don't know how they will react with the OEM rotor. I am torn between Zimmerman cross drilled and OEM. To be honest I'd prefer to stick with OEM because I've heard some bad stories with cross drilled. I just don't want the Hawk pad to eat up the rotor.
<img src='http://www.geocities.com/royb9t8/MY_BMW_2.jpg' border='0' alt='user posted image' />
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline   Reply With Quote
Old 01-03-2005, 08:24 PM   #8 (permalink)
YoungExec728 is an unknown quantity at this point
You do NOT need to bleed the brakes when replacing rotors and pads. If you do want to bleed the brakes you must do all of them, not just the fronts. The C-clamp method works, but i always use a slotted pipe wrench covered in a towel.
Here is a good link to help you out. It's for rear brakes, but it's exactly the same except for the parking brake adjustments. Good luck http://www.smithnet.ca/bmwclub_faqs/e36_re...rakes/start.htm
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 01-04-2005, 07:55 AM   #9 (permalink)
93 325i's Avatar
[snapback]263364[/snapback]
To do the whole job including labor would be $400..At least that is what they told me..Seems a bit outrageous to me but for the stealership it sounds about right for what they would charge. I already got ass raped for $1500 and I refuse to give them any more of my money..
My 1993 325i
Old 01-04-2005, 07:59 AM   #10 (permalink)
93 325i's Avatar
[snapback]263554[/snapback]
Thank you! Did you use anti-squeal stuff on the contact points? The bentley talks about using it but am wonder if I have to use it..
My 1993 325i
Old 01-04-2005, 08:53 AM   #11 (permalink)
BlantonG13's Avatar
You shouldn't have to...the hawks are a composite material if I'm not mistaken, so it won't squeal. Bavauto.com has the sensors for even cheaper (I thoguht I saw them for like $7). The dealer I went to for my clutch replacement said they would give me sensors for $29 a piece...hows that for a rip...
1996 318i
5 Speed Manual
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Old 01-04-2005, 10:21 AM   #12 (permalink)
[snapback]263939[/snapback]
Yes I used the anti-squeal brake quiet. There are two versions; a paste and a spray on. I used the spray on stuff. It's real easy, just spray the back of the pads with it before installing them. A light coat goes a long way. Make sure you put some old newspaper or something under the pads before spraying them though because the spray won't wipe up. Now i have blue brake pad outlines on my garage floor, haha. It's only a few bucks and an extra 2 mins, a few seconds to spray and let dry for about a min. So why not do it for added insurance?
Old 01-04-2005, 12:31 PM   #13 (permalink)
93 325i's Avatar
true, I ordered an anti squeal paste from bavauto plus 2 new rotor hold down bolts. Simple step to do so why not do it..
My 1993 325i
Old 01-04-2005, 05:31 PM   #14 (permalink)
Threadkiller
bitcore's Avatar
This job's fairly easy.
I used the paste and that would probably be better since only part of the back of the pad touches the caliper. You can put it where you need it and not have to hold the pad by the edges so you don't get the gunk all over the place
If you have an extra 45 minutes, I guess I'd flush the lines if you have never had that done or at least bleed them out, I would have if I had some fluid and a pressure bleeder. Oh well.
325i Front Brakes M3wannabe2004 3-Series (E36) 1 09-11-2005 01:49 PM
Cont Arms, Wheel Well, Front Brakes netgeek 3-Series (E46, E90) 8 08-26-2005 07:12 PM
Brakes Front Rotors And All Pads camnipotent 3-Series (E36) 4 07-26-2005 07:29 PM
New Front Brakes... doughboyea 3-Series (E46, E90) 8 08-19-2004 12:19 PM
Brakes (front) GreenDragon 3-Series (E36) 12 06-26-2003 10:28 PM
