Front Alignment - NEED HELP - BMW Forum - BimmerWerkz.com
Old 06-20-2006, 05:03 AM   #1 (permalink)
L3VND1 is on a distinguished road
Hi guys,
Im new to the forum. Been driving my E36 318is now for about a year.
It is '98 and has the M kit on it.
Ive had a few modifications done to it but I had an incident driving the other day that im concerned about.
I exited a corner and lost control and hit/mounted a traffic island.
I scraped the front spoiler and hit my front right on it pretty hard.
The impact caused a stress point in my windshield and cracked it. Also i had replica E46 M3 (18inch) rims on it that got scratched as well.
However now the right wheel sits about a centimeter further back than the left and scrapes the inside guard when i turn sharply.
Would alignment fix this problem? Or do i have something more seroius on my hands.
I am trying to hold out to friday because I have H&R springs coming to lower the car where they will wheel align there.
The car is drivable but yeah. What do you guys think it is? Would alignment fix it? If not, what is it and how much am i in for?
Cheers.
L3VND1 is offline   Reply With Quote
Old 06-20-2006, 07:32 AM   #2 (permalink)
Redbullrr's Avatar
Redbullrr is on a distinguished road
Seems like you bent the Lower Control Arm, this will have to be replaced in order. Thats my opinion.
Redbullrr is offline   Reply With Quote
Old 06-21-2006, 02:20 AM   #3 (permalink)
ok. thanks. I'll look into it.
Old 06-21-2006, 04:06 PM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Defintely sounds like a lower control arm. You might also need to replace your lower control arm bushing. The lower control arm i ment to bend in situations like you just had in order to prevent even further destruction of your suspension. Also take a look at your tie rod.
Old 06-21-2006, 05:30 PM   #5 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
What said above + check out your ball joint. If you are getting new CA arms you can get some that have ball joints already pressed in, saves labor time and headaches.
-Serge
theruss1an1 is offline   Reply With Quote
Old 06-21-2006, 05:46 PM   #6 (permalink)
Threadkiller
bitcore's Avatar
Replace LCA. Replace your LCA bushings (yes, both of them) You may be interested in the solid M3 bushings, I STRONGLY suggest them, it firms up the front quite alot. Replace tie-rods (rodS, both of them). Unless you simply cannot afford it, you may pass on this one (tie rods) IF they are NOT damaged. Check your strut for bends & leaking fluid - replace if it's damged (replace in pairs) - otherwise the fluid will leak out and you will be left with just a spring and no damping = bouncey bouncey. Rebalence your wheels and get it strightened since there surely is a bend in the rim now.
The LCA is not optional, duh, the LCA bushings get destroyed when you remove the control arm from the eyeballs, so you might as well get the M3 ones when you replace it. Tie rods are qute important - if one snaps, you will loose control.
Take it easy dude, when you hit stuff, LOTS of things get damaged. You may not notice the damage under visual inspection, but it's there.
Alignment 101 441tech 3-Series (E46, E90) 4 12-10-2009 10:46 AM
Proper Alignment is VERRY Important! Eric S. 5-Series (E12,E28, E34, E39, E60) 6 12-27-2005 06:43 PM
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 06:44 AM
Help wiring up amp install lude69 Audio and Electronics 13 08-15-2004 10:24 AM
front end alignment??? tknesek 1,6,7,8 - Series and Mini Cooper 1 04-23-2004 11:29 PM
